Inconveniences high times between switch's
  • Problem
  • Updated 4 years ago
Good day, I have a sw A4 FW 06.71.03.0025 connected by optical fiber to a C5 FW: 06.71.03.0025 when no user response times are good 1ms, 2ms but when there is traffic on the network and users working times are than 1000ms or 2000ms. which may be causing this problem? as I can fix?
Photo of David Cadena
David Cadena
  • 80 Points 75 badge 2x thumb
Posted 4 years ago
Photo of Stephan Heyer
Stephan Heyer
  • 64 Points
try to disable flow control in the A4 switch (set flowcontrol disable). This helped when I've had the same problem.
David Cadena
Already applied, but this problem continues.
Photo of JAMES WIEDEL
JAMES WIEDEL
  • 780 Points 500 badge 2x thumb
There are lots of possibilities, but are you getting any errors on the inter-switch link? (show port counters on both ends)     Another possibility is that there is a multicast flood clogging up the link.
A "bad" user's NIC that is spewing out packets can foul things up too.
I am assuming the optical link is at least as fast if not faster than the attached systems...
  James
