Industrial Switch ISW - Auth/EAP question
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hi Guys,
There's any info on the ISW (Industrial Switches) related to authentication?
I find out it have some sort of "policy", but not the regular Enterasys/Extreme Policy, something like ACLs.
As I have some customers interested (and actually testing Transitions and other brands) with large Enterasys/Extreme installed bases, it could be very interesting, as I-Series is not available (at least here in Brazil) anymore.
The major question is if ISW will have some kind of "EAP Pass-Through" feature, like 800 Series, allowing users to be multi-authed on a upstream switch (G-Series / S-Series). If available, it should be awesome.
Best regards,
-Leo
Photo of Leonardo Peixoto
Leonardo Peixoto
  • 2,212 Points 2k badge 2x thumb
  • confident
Posted 2 years ago
Photo of James A
James A, Embassador
  • 6,542 Points 5k badge 2x thumb
The new X440-G2 has some models that can handle environments up to 60oC which are marketed as possible replacements for the I-Series if that's the reason you need industrial-grade switches.
Photo of Christina M
Christina M, Lead Technical Editor, Information Development
  • 1,416 Points 1k badge 2x thumb
Hello!
Have you checked the recently released documentation at http://documentation.extremenetworks.com/industrial_switches/web_config/index.html? If
the information you seek is missing, kindly click the Feedback link so we can add this improvement to the queue.
Thanks!
(Edited)
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
Hello Christina,
your link does not work for me, but the following one did:
http://documentation.extremenetworks.com/industrial_switches/web_config/Industrial_Switching/Web_Use...
Erik
Thanks for letting me know. I've updated the link.
Leonardo Peixoto
Hi Guys,
The X440-G2 are not suitable for our customer needs... As the switch needs to work on a "hazardous" area (manufacturing) they use I-Series today and need some IPxx protection.
I saw at the Partner Portal about this new ISW series, but without much information, such as the questions I've raised above.
Best regards,
-Leo
Photo of Matthew Roman
Matthew Roman, Employee
  • 60 Points
The new Industrial switches do not pass through EAP packets. This pass through mode is under consideration for a future release. The products do natively support 802.1X and MAC address based authentication.
Regards,
MattĀ
