Info:pim.vsm.UnkIPNetAddr what does this actually means
  • Question
  • Updated 4 years ago
What does this alarm from the log actually tell me..
Searching the web :
Description
This event occurs when an MLAG node receives a checkpoint message from the peer with ingress
VLAN IP address information that does not match any of the MLAG VLANs configured on the local
node.
Remedy
Ensure that MLAG VLANs are configured with correct IP addresses and mask length on MLAG
peer nodes. If the IP addresses do not match for MLAG VLANs then PIM may not function as
expected.​
Though personally I do not agree with the MLAG configuration issue as this has been working and not changed for months..
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 4 years ago
Photo of Annas Shaker
Annas Shaker, Alum
  • 240 Points 100 badge 2x thumb
Rod, How often is this message showing up in the log?
Annas Shaker, Alum
Also, are you seeing this message on a switch where MLAG is configured?
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
I would like to see the entire logs
Also what exos version are you running
15.3.1.4 latest patch for mlag .
Many customer run this exos with no issues.
