Info Vlan DGB
  • Question
  • Updated 2 years ago
  • Answered
Hello Community, i have a loop in my network, the switch sample this log
<Info:vlan.dbg.info> Toggling AdminState on Port 13 with pif 0x5c9ca0
Someone else has had this log. The version is 16.1.4.2 patch1-7.
Photo of Susana Tovar
Susana Tovar
  • 494 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
Hello Susana,
What protocol are you using for loop prevention. This looks like a log that would be coupled with another log. STP or ELRP, maybe?
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
As already said by Patrick, that message usually appears after a possible "automatic disabled port" action triggered by a loop prevention protocol like ELRP or STP.
Susana Tovar
Hello boys, The protocol are using is ELRP.
Photo of Henrique
Henrique, Employee
Hi Susana, could you please share the output for "show configuration elrp"?
Susana Tovar
Hello Henrique,
This is configuration
enable elrp-client
configure elrp-client disable-ports exclude eaps-ring-ports
configure elrp-client periodic salaservidores ports all interval 1 log-and-trap disable-port egress permanent
Thanks.
Photo of Henrique
Henrique, Employee
Hi Susana, based on your ELRP configuration, that log message means the port admin state was changed from "enabled" to "disabled" (triggered by your ELRP configuration) due to the loop found by ELRP.
That's an informational message and expected.
You will need to enable the port manually.
Susana Tovar
Hello Henrique,
Thanks for your information.
Regards.
Patrick Voss, Alum
Hello Susana,
Do you currently have a loop in the network? Were there any ELRP logs on the switch?
Susana Tovar
Hello Patrick,
In this moment not have loop. I enable port 13. In fin in the othe switch That does not have configurated elrp. Thank you for your help.
Regards.
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
Susana hope this is sorted out already. Hence could we close this HUB discussion moving forward?
