Initial Configuration BD8810
  • Question
  • Updated 10 months ago
  • Answered
  • (Edited)
Hello Expert,
Im start configuring my first BD8810:
First I want to upgrade the node, but for that I configure a vlan with an IP Address but Im unable to ping the IP. [My computer has the 192.168.1.2/24]
This is my config:
enable port 1:1
create vlan "test"
configure vlan test tag 10
configure vlan test add ports 1:1 untagged
configure vlan test ipaddress 192.168.1.1 255.255.255.0
enable ipforwarding vlan test
There is something that I missing??  Maybe something new for the BlackDiamonds
Thanks
Photo of Mario Cruz Torres
Mario Cruz Torres
  • 190 Points 100 badge 2x thumb
Posted 11 months ago
Photo of Ariyakudi Srinivas, Muthuraman
Ariyakudi Srinivas, Muthuraman, Employee
  • 994 Points 500 badge 2x thumb
Hi Mario Cruz,
I see all the necessary configuration for the communication to happen between the PC (192.168.1.24/24) and the BD8810 (192.168.1.1/24).
I don't see a reason as to why the ping will not go through between the switch and the PC.
Is there any firewall that is enabled in the PC that could be taken down and checked?
What about the port LED status and please check the output of "show port 1:1" to see if the status of the port is "Enabled" and "Active".
Thank You,
Muthuraman
Mario Cruz Torres
Hello Muthuraman,
I remove the firewall on my laptop and the same issue.
The port is Active no issue with the cable.
There is something new for the BD to configure?? Like the modules? We just power on the equipments.
Thanks for the quick response.
(Edited)
Hi Mario Cruz,
Is ping from both the direction not functional or is the ping in any 1 direction not functional.
Also, please check the output of "show fdb port 1:1" to see if the MAC of the PC is learnt in the switch. And also check the output of "show iparp" to see if the IP address of the PC is learnt in the switch.
Let us also check if there are any errors occurring in the port and the command is as below,
- show port 1:1 rxerror
- show port 1:1 txerror
Thank You,
Muthuraman
Mario Cruz Torres
Ping is not functional in both directions.
The MAC is learned via the fdb command but no via the iparp, And looking for the errors there is no such on the port.
Any idea.
Thanks
Mario
Hi Mario Cruz,
Please share the complete output of "show port 1:1 information detail" and "show switch" from the BD8810.
Thank you,
Muthuraman
Mario Cruz Torres
Follow the info:
* BD-8810.165 # sh ports 1:1 information detail
Port: 1:1
Virtual-router: VR-Default
Type: UTP
Random Early drop: Unsupported
Admin state: Enabled with  auto-speed sensing  auto-duplex
Link State: Active, 1Gbps, full-duplex
Link Ups:       11       Last: Sun Sep 24 14:38:17 2017
Link Downs:     10       Last: Sun Sep 24 14:33:56 2017
VLAN cfg:
Name: test, Internal Tag = 100, MAC-limit = No-limit, Virtual router:   VR-Default
STP cfg:
Protocol:
Name: test         Protocol: ANY      Match all protocols.
Trunking: Load sharing is not enabled.
EDP: Enabled
ELSM: Disabled
Ethernet OAM: Disabled
Learning: Enabled
Unicast Flooding: Enabled
Multicast Flooding: Enabled
Broadcast Flooding: Enabled
Jumbo: Disabled
Flow Control: Rx-Pause: Enabled Tx-Pause: Disabled
Priority Flow Control: Disabled
Reflective Relay: Disabled
Link up/down SNMP trap filter setting: Enabled
Egress Port Rate: No-limit
Broadcast Rate: No-limit
Multicast Rate: No-limit
Unknown Dest Mac Rate: No-limit
QoS Profile: None configured
Ingress Rate Shaping : Unsupported
Ingress IPTOS Examination: Disabled
Ingress 802.1p Examination: Enabled
Ingress 802.1p Inner Exam: Disabled
Ingress 802.1p Priority:        0
Egress IPTOS Replacement: Disabled
Egress 802.1p Replacement: Disabled
NetLogin: Disabled
NetLogin port mode: Port based VLANs
Smart redundancy: Enabled
Software redundant port: Disabled
IPFIX:   Disabled Metering:  Ingress, All Packets, All Traffic
IPv4 Flow Key Mask: SIP: 255.255.255.255 DIP: 255.255.255.255
IPv6 Flow Key Mask: SIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
DIP: ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff
auto-polarity: Enabled
Shared packet buffer: default
VMAN CEP egress filtering: Disabled
Isolation: Off
PTP Configured:       Disabled
Time-Stamping Mode:   None
Dynamic VLAN Uplink:           Disabled
VM Tracking Dynamic VLANs:     Disabled
* BD-8810.166 # show switch
SysName:          BD-8810
SysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
System MAC:       00:04:96:9C:C0:60
System Type:      BD-8810
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Sun Sep 24 14:39:11 2017
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Thu Sep 21 15:24:17 2017
Boot Count:       3
Next Reboot:      None scheduled
System UpTime:    2 days 23 hours 14 minutes 54 seconds
Slot:             MSM-A *                      MSM-B
Current State:    MASTER                       BACKUP (In Sync)
Image Selected:   primary                      primary
Image Booted:     primary                      primary
Primary ver:      16.1.3.6                     16.1.3.6
Secondary ver:    16.1.3.6                     16.1.3.6
Config Selected:  NONE                         NONE
Config Booted:    Factory Default              Factory Default
Thanks so much for this help
Mario Cruz
Hi Mario Cruz,
The port seems to have the right configuration and the broadcast is enabled in the switch.
Please run wireshark in the PC and initiate a ping to the switch IP address and see if there are any ARP reply received from the switch.
Thank You,
Muthuraman
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,816 Points 10k badge 2x thumb
Can we see a "show vlan" output, "show port 1:1 vlan" (should be there in 16.1) and a "show vlan 100" (as it seems the port is in vlan 100, not 10)?
Photo of EtherMAN
EtherMAN, Embassador
  • 6,628 Points 5k badge 2x thumb
Another way to confirm is
show fdb port 1:1 .....
fdb entry will show what vlan the switch is learning the mac address on... does sound like you may have created another vlan with tag id 100 that is untagged on port 1:1 so when you tried to add test untagged it should have returned a warning that there was already an untagged vlan on that port.
Show ipr vr vr-def would also confirm what vlan and tag the ip is on
Mario Cruz Torres
Hello I verify,
I changed to another config:
# Module devmgr configuration.
configure snmp sysContact "support@extremenetworks.com, +1 888 257 3000"
configure slot 1 module G48Tc
configure sys-recovery-level slot 1 reset
configure slot 2 module G48Tc
configure sys-recovery-level slot 2 reset
configure slot 10 module 8900-10G8X-xl
configure sys-recovery-level slot 10 reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1:1-48,2:1-48,10:1-8
configure vr VR-Default add ports 1:1-48,2:1-48,10:1-8
configure vlan default delete ports 1:3-4
create vlan "test"
configure vlan test tag 300
configure vlan Default add ports 1:1-2,1:5-48,2:1-48,10:1-8 untagged
configure vlan test add ports 1:3-4 untagged
configure vlan test ipaddress 10.0.0.1 255.255.255.252
* BD-8810.69 # sh fdb
Mac                     Vlan       Age  Flags           Port / Virtual Port List
d0:bf:9c:22:17:23       test(0300) 0044  d m            1:3
Flags : d - Dynamic, s - Static, p - Permanent, n - NetLogin, m - MAC, i - IP,
        x - IPX, l - lockdown MAC, L - lockdown-timeout MAC, M- Mirror, B - Egress Blackhole,
        b - Ingress Blackhole, v - MAC-Based VLAN, P - Private VLAN, T - VLAN translation,
        D - drop packet, h - Hardware Aging, o - IEEE 802.1ah Backbone MAC,
        S - Software Controlled Deletion, r - MSRP,
        R - TRILL Rbridge, Z - OpenFlow
Total: 1 Static: 0  Perm: 0  Dyn: 1  Dropped: 0  Locked: 0  Locked with Timeout: 0
FDB Aging time: 300
* BD-8810.70 # show ipr vr "VR-Default"
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#d   10.0.0.0/30        10.0.0.1        1    U------um--f- test       0d:0h:31m:5s
       (mo) MOSPF (o) OSPF, (o1) OSPFExt1, (o2) OSPFExt2,
       (oa) OSPFIntra, (oe) OSPFAsExt, (or) OSPFInter, (pd) PIM-DM, (ps) PIM-SM,
       (r) RIP, (ra) RtAdvrt, (s) Static, (sv) SLB_VIP, (un) UnKnown,
       (*) Preferred unicast route (@) Preferred multicast route,
       (#) Preferred unicast and multicast route.
Flags: (b) BFD protection requested, (B) BlackHole, (c) Compressed, (D) Dynamic,
       (f) Provided to FIB, (G) Gateway, (H) Host Route, (l) Calculated LDP LSP,
       (L) Matching LDP LSP, (m) Multicast, (p) BFD protection active, (P) LPM-routing,
       (R) Modified, (s) Static LSP, (S) Static, (t) Calculated RSVP-TE LSP,
       (T) Matching RSVP-TE LSP, (u) Unicast, (U) Up, (3) L3VPN Route.
MPLS Label: (S) Bottom of Label Stack
Mask distribution:
     1 routes at length 30
Route Origin distribution:
     1 routes from Direct
Total number of routes = 1
Total number of compressed routes = 0
Everything looks fine but ping is not OK
* BD-8810.52 # ping vr "VR-Default" 10.0.0.2
Ping(ICMP) 10.0.0.2: 4 packets, 8 data bytes, interval 1 second(s).
--- 10.0.0.2 ping statistics ---
4 packets transmitted, 0 packets received, 100% loss
round-trip min/avg/max = 0/0/0 ms
I verify that the 10.0.0.1 ping [The IP on the switch] is ok.
* BD-8810.76 # ping vr "VR-Default" 10.0.0.1
Ping(ICMP) 10.0.0.1: 4 packets, 8 data bytes, interval 1 second(s).
16 bytes from 10.0.0.1: icmp_seq=0 ttl=64 time=0.433 ms
16 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=0.161 ms
16 bytes from 10.0.0.1: icmp_seq=2 ttl=64 time=0.164 ms
16 bytes from 10.0.0.1: icmp_seq=3 ttl=64 time=0.154 ms
--- 10.0.0.1 ping statistics ---
4 packets transmitted, 4 packets received, 0% loss
* BD-8810.77 #
Something maybe wrong with the Switch?
Thanks
Photo of simon bingham
simon bingham
  • 1,196 Points 1k badge 2x thumb
I think this issue will be if you new to Extreme the you are not using "VR-Default" and by default you are pinging from the MGMT
try this
ping vr "VR-Default" 192.168.1.2
let me know if that works
(Edited)
simon bingham
please note there was a typo in my original response I have corrected but it should have read
Mario Cruz Torres
I change the config [above]
Trying to ping correctly not working
* BD-8810.77 #
Mario Cruz Torres
Maybe is need it a License??
Photo of EtherMAN
what does show iparp say?  If you have an arp entry for the 10.0.0.2 in the test vlan with the mac of your laptop then your laptop still has a firewall enabled and is block icmp.
Your configuration looks good
Photo of Andrew Imam
Andrew Imam, Alum
  • 1,026 Points 1k badge 2x thumb
Hi Mario,
Your config looks OK to me. I still suspect an issue with the FW on your computer. Can you try to totally disable it again, restart the PC and retest. Please let us know the outcome after performing those steps. Thank you.
Best regards,
Andrew
Mario Cruz Torres
Hello,
I think we solve the issue we removed the MSM Master and change it. After this the ping was ok..
Do you think that this card is faulty?
Thanks everyone
Mario Cruz
Andrew Imam, Alum
Mario,
Thanks for the update. I would suggest running extended diagnostics on the removed MSM (if you can insert it in another lab chassis if available), your can use the command" "run diagnostics extended msm <A or B>" to run the extended diags. This will reboot the MSM, and run the diag tests. When the tests are completed and the MSM becomes operational, you can use the "show diag" to check on the results of the diagnostics. If the issue persist with the MSM, please collect the "show tech all", "show log messages nvram" outputs from the MSM and open a case with Extreme GTAC for further investigation.
Thank you.
Best regards,
Andrew
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
There is the article for ”Diagnostics” EXOS.
How to Diagnose-hardware failures using EXOS
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Diagnose-hardware-failures-using-EX...
Best regards,
