Inline Power System information missing / No POE on otherwise working switch X440
  • Problem
  • Updated 5 months ago
  • Solved
I am looking at two X440-48Poe switches, both working with 15.7.1.4 XOS. One switch supplies POE and the other does not. On the working switch SHOW INLINE-POWER returns the firmware status and power wattage information. On the switch that does not supply POE (otherwise working) the command returns no firmware or power wattage information, its just missing. Is this a bad power supply? I tried UNCONFIGURE SWITCH, didn't help.
Photo of Wesley
Wesley
  • 122 Points 100 badge 2x thumb
Posted 5 months ago
Photo of Eric Burke
Eric Burke
  • 2,144 Points 2k badge 2x thumb
I believe inline will only show POE stats, not general power supply stats.  Try "sho power detail".
Photo of Wesley
Wesley
That command says internal power supply state 'Powered On'
Photo of Eric Burke
Eric Burke
Just re-read your post (was thinking one was POE and one was not).  I'd be curious to see what "show power" says.  I do believe that a POE device that's not providing power would still show it as active.  Strange.
Photo of Eric Burke
Eric Burke
Looking at a couple of mine and they all show stats, even if not providing power.  Hopefully, someone else will have some idea...  Good luck.
Photo of Eric Burke
Eric Burke
Perhaps a silly question - if you issue an "en inline", does it return any errors or anything?
Photo of Wesley
Wesley
It shows that it is enabled. No errors. Sho inline still missing the Firmware and wattage portion.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,402 Points 5k badge 2x thumb
Check patch cables.
If you have device being powered from one X440 and connect it to other X440 with the same firmware and it is not getting PoE then the issue seems to be in the HW or in the config.
If you unconfigure switch all (you did) and you still do not receive PoE then I believe it is reason for RMA (if you have support service contract).
Photo of Necheporenko, Nikolay
Necheporenko, Nikolay, Employee
  • 1,350 Points 1k badge 2x thumb
Hello Wesley,
Have you tried command "run diagnostic extended" and then "show diag"?
Please check next article for more details - https://gtacknowledge.extremenetworks.com/articles/Solution/Summit-PoE-failure-and-switch-pass-exten...
Best Regards,
Nikolay
Photo of Wesley
Wesley
Thanks everyone, it looks like hardware failure. Extended diagnostics show "POE check state loop test failed"
