Installing both Ridgeline and NetSight on Same PC
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
Hi
I installed Ridgeline 4.0 with SP2 and worked fine on my Laptop. I used port http://my-pc:9090.
then I installed Netsight on the same Laptop and accepted the default setting (assuming port 8080). When Netsight installation was done and  tryied (http://my-pc:8080) nothing came.
when trying Netsight Server Manager , I got error ( Unable to find Java Runtime. Application shutting down)
I am using Win 7 Professional 64-bit and installed Netsight for Win -64-bit 6.2.0.211 using 3 months Evaluation License
any recommendation ?
Regards
Khaled
Photo of Al-Najjar, Khaled
Al-Najjar, Khaled, Employee
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Rainer Adam
Rainer Adam
  • 874 Points 500 badge 2x thumb
You have to start the "Application Services" and after a few minutes the services should be all running, check it with the red mouse button over the icon in symbols. I am sure that your Netsight Server (and therefor also the http service is not started).
But please hold in mind that on a single PC only ONE service can run at the same time (tftp, syslog-service and trap service) and only ONE application will get the syslog's and traps.
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,650 Points 5k badge 2x thumb
I think a netstat may show some port conflicts, and here is a method to alter the ports in Netsight.
Please use the following Knowledgebase article for guidance on switching over the default ports for Netsight.
https://gtacknowledge.extremenetworks.com/articles/Solution/Netsight-fails-to-launch-404-error
Although I am not certain that the Java error is related to that. Please run through article and verify.
