inter vlan issue
  • Problem
  • Updated 2 months ago
  • Solved
in core switch,i configured intervlan,intervlan is not working.
configured 2 vlans in core switch-data and voice and enable the ipforwarding also.
not working the intervlan.
Photo of Ranjith
Ranjith
  • 280 Points 250 badge 2x thumb
Posted 2 months ago
Photo of Ed Uhler
Ed Uhler, Employee
  • 160 Points 100 badge 2x thumb
Photo of Ranjith
Ranjith
I tried this way,still not solved this 8ssue
Photo of Ed Uhler
Ed Uhler, Employee
Photo of Ed Uhler
Ed Uhler, Employee
Download this jpg image to get more detail.  This is just an example on how to setup the three independent switches. I'm showing that the L2 VLAN's (DATA and VOICE) are extended across all three switches, but only Switch-2 is doing the Inter-VLAN routing for the two subnets.
Photo of Ed Uhler
Ed Uhler, Employee
Ranjith -- I realized that I forgot to add port 23 to Switch-2 configuration, so please disregard the first illsutration.... I've correct and added this second illustration.
Photo of Ed Uhler
Ed Uhler, Employee
Ranjith... If you want to create a L3 routed network, then here's a RIP network example that you can try.
Photo of Ranjith
Ranjith
I have 2 core switch,both switch network is different i configued intervlan also.still it is not communicating.what is the issue.please help
Photo of Robert Cummins
Robert Cummins
  • 612 Points 500 badge 2x thumb
It would help to see:
 - all vlans on all switches
 - routing tables from all switches
Is there any reason to run rip?
Photo of Ranjith
Ranjith
both switch vlan ID is differenent also a Network Also.
what is the solution for solve this issue
