Inter-VLAN Routing not working correctly
  • Problem
  • Updated 4 weeks ago
Hello!
I just took over a System Administrator role for a company and trying to figure out what happened to one of their VLANs.
I am new to the Extreme Network devices. They currently have 3 stacked X450-e as their main switch stack/router.
The previous SA setup a new VLAN (VLAN11) to free up some IPs on the main subnet.
Some PCs started dropping from the network last week and we ended up figuring out that the VLAN had been removed from the switch configuration.
I readded it and tried to set everything up as it should be but its not working and I am starting to bang my head against the wall and need some other eyes on this to tell me where the issue might be.
I've gone through all the help guides on here and cannot get a PC to ping another PC on VLAN11 from VLAN1. I cannot even get VLAN11 to pass DHCP to the PC. Static set IP doesn't work either.
DHCP server IP is 192.168.0.17
Here is my current switch config:
login: admin
password:
ExtremeXOS
Press the <tab> or '?' key at any time for completions.
Remember to save your configuration changes.
# show configuration "nettools"
# Module netTools configuration.
configure sntp-client primary 192.168.0.151 vr VR-Default
configure bootprelay add 192.168.0.17 vr VR-Default
enable bootprelay vlan Default
enable bootprelay vlan VLAN11
* Slot-1 *****.1 # show configuration
# Module devmgr configuration.
configure snmp sysName "*****"
configure timezone name CDT -360 autodst
configure slot 1 module X450e-48p
configure sys-recovery-level slot 1 reset
configure slot 2 module X450e-48p
configure sys-recovery-level slot 2 reset
configure slot 3 module X450e-48t
configure sys-recovery-level slot 3 reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1:1-50, 2:1-50, 3:1-50
configure vr VR-Default add ports 1:1-50, 2:1-50, 3:1-50
configure vlan default delete ports 1:41, 2:13, 2:21-22, 2:30, 2:48, 3:7, 3:11, 3:16, 3:41, 3:46-47
create qosprofile "QP3"
create qosprofile "QP4"
create qosprofile "QP5"
create qosprofile "QP6"
configure vlan Default qosprofile QP3
create vlan "replication"
configure vlan replication tag 80
create vlan "VLAN11"
configure vlan VLAN11 tag 11
create vlan "VOICE"
configure vlan VOICE tag 10
configure vlan VOICE qosprofile QP6
configure ports 1:16 auto off speed 100 duplex full
configure ports 1:32 auto off speed 100 duplex full
enable jumbo-frame ports 1:45
configure ports 1:45 preferred-medium copper
enable jumbo-frame ports 1:46
configure ports 1:46 preferred-medium copper
enable jumbo-frame ports 1:47
configure ports 1:47 preferred-medium copper
enable jumbo-frame ports 1:48
configure ports 1:48 preferred-medium copper
enable jumbo-frame ports 1:49
enable jumbo-frame ports 2:45
configure ports 2:45 preferred-medium copper
enable jumbo-frame ports 2:46
configure ports 2:46 preferred-medium copper
enable jumbo-frame ports 2:47
configure ports 2:47 preferred-medium copper
enable jumbo-frame ports 2:48
configure ports 2:48 preferred-medium copper
enable jumbo-frame ports 3:45
configure ports 3:45 preferred-medium copper
enable jumbo-frame ports 3:46
configure ports 3:46 preferred-medium copper
enable jumbo-frame ports 3:47
configure ports 3:47 preferred-medium copper
enable jumbo-frame ports 3:48
configure ports 3:48 preferred-medium copper
enable sharing 2:47 grouping 2:47, 3:47 algorithm address-based L2 lacp
enable sharing 2:46 grouping 2:46, 3:46 algorithm address-based L2 lacp
configure vlan Default add ports 2:13 tagged
configure vlan Default add ports 1:1-40, 1:42-50, 2:1-12, 2:14-20, 2:23-29, 2:31-47, 2:49-50, 3:1-6, 3:8-10, 3:12-15, 3:
17-40, 3:42-45, 3:48-50 untagged
configure vlan replication add ports 2:48 untagged
configure vlan VLAN11 add ports 1:41, 2:21, 2:30, 3:7 untagged
configure vlan VOICE add ports 1:1-50, 2:1-50, 3:19, 3:40, 3:42, 3:44, 3:49-50 tagged
configure vlan VOICE add ports 3:41 untagged
configure vlan Default ipaddress 192.168.0.1 255.255.255.0
enable ipforwarding vlan Default
configure vlan VOICE ipaddress 192.168.100.1 255.255.255.0
enable ipforwarding vlan VOICE
configure vlan replication ipaddress 10.90.0.1 255.255.255.248
enable ipforwarding vlan replication
configure vlan VLAN11 ipaddress 192.168.11.1 255.255.255.0
enable ipforwarding vlan VLAN11
configure qosprofile QP3 maxbuffer 100 weight 1
configure qosprofile QP4 maxbuffer 100 weight 1
configure qosprofile QP5 maxbuffer 100 weight 1
configure qosprofile QP6 maxbuffer 100 weight 1
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:1
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:1
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:1
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:1
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:2
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:2
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:2
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:2
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:3
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:3
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:3
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:3
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:4
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:4
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:4
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:4
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:5
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:5
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:5
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:5
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:6
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:6
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:6
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:6
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:7
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:7
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:7
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:7
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:8
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:8
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:8
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:8
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:9
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:9
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:9
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:9
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:10
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:10
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:10
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:10
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:11
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:11
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:11
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:11
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:12
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:12
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:12
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:12
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:13
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:13
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:13
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:13
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:14
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:14
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:14
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:14
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:15
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:15
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:15
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:15
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:16
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:16
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:16
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:16
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:17
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:17
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:17
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:17
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:18
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:18
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:18
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:18
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:19
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:19
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:19
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:19
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:20
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:20
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:20
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:20
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:21
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:21
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:21
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:21
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:22
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:22
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:22
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:22
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:23
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:23
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:23
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:23
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:24
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:24
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:24
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:24
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:25
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:25
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:25
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:25
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:26
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:26
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:26
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:26
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:27
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:27
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:27
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:27
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:28
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:28
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:28
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:28
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:29
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:29
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:29
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:29
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:30
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:30
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:30
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:30
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:31
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:31
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:31
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:31
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:32
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:32
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:32
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:32
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:33
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:33
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:33
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:33
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:34
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:34
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:34
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:34
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:35
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:35
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:35
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:35
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:36
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:36
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:36
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:36
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:37
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:37
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:37
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:37
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:38
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:38
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:38
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:38
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:39
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:39
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:39
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:39
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:40
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:40
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:40
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:40
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:41
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:41
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:41
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:41
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:42
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:42
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:42
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:42
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:43
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:43
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:43
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:43
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:44
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:44
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:44
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:44
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:45
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:45
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:45
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:45
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:46
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:46
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:46
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:46
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:47
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:47
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:47
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:47
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:48
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:48
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:48
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:48
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:49
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:49
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:49
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:49
configure qosprofile QP3 minbw 0 maxbw 100 ports 1:50
configure qosprofile QP4 minbw 0 maxbw 100 ports 1:50
configure qosprofile QP5 minbw 0 maxbw 100 ports 1:50
configure qosprofile QP6 minbw 0 maxbw 100 ports 1:50
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:1
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:1
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:1
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:1
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:2
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:2
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:2
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:2
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:3
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:3
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:3
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:3
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:4
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:4
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:4
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:4
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:5
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:5
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:5
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:5
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:6
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:6
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:6
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:6
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:7
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:7
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:7
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:7
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:8
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:8
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:8
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:8
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:9
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:9
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:9
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:9
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:10
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:10
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:10
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:10
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:11
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:11
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:11
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:11
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:12
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:12
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:12
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:12
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:13
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:13
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:13
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:13
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:14
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:14
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:14
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:14
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:15
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:15
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:15
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:15
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:16
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:16
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:16
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:16
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:17
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:17
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:17
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:17
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:18
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:18
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:18
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:18
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:19
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:19
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:19
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:19
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:20
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:20
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:20
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:20
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:21
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:21
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:21
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:21
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:22
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:22
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:22
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:22
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:23
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:23
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:23
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:23
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:24
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:24
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:24
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:24
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:25
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:25
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:25
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:25
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:26
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:26
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:26
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:26
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:27
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:27
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:27
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:27
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:28
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:28
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:28
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:28
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:29
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:29
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:29
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:29
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:30
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:30
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:30
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:30
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:31
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:31
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:31
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:31
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:32
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:32
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:32
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:32
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:33
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:33
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:33
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:33
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:34
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:34
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:34
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:34
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:35
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:35
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:35
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:35
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:36
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:36
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:36
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:36
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:37
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:37
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:37
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:37
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:38
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:38
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:38
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:38
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:39
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:39
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:39
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:39
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:40
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:40
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:40
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:40
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:41
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:41
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:41
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:41
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:42
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:42
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:42
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:42
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:43
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:43
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:43
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:43
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:44
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:44
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:44
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:44
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:45
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:45
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:45
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:45
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:46
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:46
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:46
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:46
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:47
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:47
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:47
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:47
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:48
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:48
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:48
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:48
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:49
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:49
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:49
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:49
configure qosprofile QP3 minbw 0 maxbw 100 ports 2:50
configure qosprofile QP4 minbw 0 maxbw 100 ports 2:50
configure qosprofile QP5 minbw 0 maxbw 100 ports 2:50
configure qosprofile QP6 minbw 0 maxbw 100 ports 2:50
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:1
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:1
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:1
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:1
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:2
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:2
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:2
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:2
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:3
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:3
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:3
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:3
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:4
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:4
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:4
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:4
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:5
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:5
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:5
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:5
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:6
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:6
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:6
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:6
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:7
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:7
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:7
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:7
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:8
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:8
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:8
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:8
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:9
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:9
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:9
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:9
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:10
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:10
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:10
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:10
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:11
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:11
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:11
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:11
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:12
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:12
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:12
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:12
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:13
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:13
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:13
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:13
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:14
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:14
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:14
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:14
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:15
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:15
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:15
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:15
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:16
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:16
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:16
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:16
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:17
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:17
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:17
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:17
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:18
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:18
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:18
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:18
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:19
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:19
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:19
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:19
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:20
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:20
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:20
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:20
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:21
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:21
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:21
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:21
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:22
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:22
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:22
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:22
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:23
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:23
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:23
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:23
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:24
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:24
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:24
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:24
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:25
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:25
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:25
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:25
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:26
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:26
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:26
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:26
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:27
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:27
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:27
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:27
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:28
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:28
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:28
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:28
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:29
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:29
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:29
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:29
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:30
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:30
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:30
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:30
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:31
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:31
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:31
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:31
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:32
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:32
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:32
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:32
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:33
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:33
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:33
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:33
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:34
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:34
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:34
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:34
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:35
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:35
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:35
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:35
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:36
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:36
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:36
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:36
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:37
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:37
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:37
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:37
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:38
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:38
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:38
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:38
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:39
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:39
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:39
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:39
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:40
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:40
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:40
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:40
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:41
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:41
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:41
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:41
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:42
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:42
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:42
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:42
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:43
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:43
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:43
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:43
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:44
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:44
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:44
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:44
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:45
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:45
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:45
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:45
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:48
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:48
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:48
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:48
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:49
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:49
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:49
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:49
configure qosprofile QP3 minbw 0 maxbw 100 ports 3:50
configure qosprofile QP4 minbw 0 maxbw 100 ports 3:50
configure qosprofile QP5 minbw 0 maxbw 100 ports 3:50
configure qosprofile QP6 minbw 0 maxbw 100 ports 3:50
# Module fdb configuration.
# Module rtmgr configuration.
configure iproute add default 192.168.0.2
# Module mcmgr configuration.
# Module aaa configuration.
configure account admin encrypted "tqTi5x$5hTa/A4gfs0ihgOAbMXNS1"
# Module acl configuration.
configure access-list zone SYSTEM application NetLogin application-priority 4
configure access-list zone SECURITY application GenericXml application-priority 2
# Module bfd configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
# Module edp configuration.
# Module elrp configuration.
enable elrp-client
configure elrp-client periodic Default ports all interval 1 log disable-port duration 30
# Module ems configuration.
# Module epm configuration.
# Module erps configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module fcoe configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lacp configuration.
# Module lldp configuration.
enable lldp ports 1:1
configure lldp port 1:1 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:1 advertise vendor-specific dot1 vlan-name
configure lldp port 1:1 advertise vendor-specific avaya-extreme call-server 192.168.100.254
 configure lldp port 1:1 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:1 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:2
configure lldp port 1:2 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:2 advertise vendor-specific dot1 vlan-name
configure lldp port 1:2 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:2 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:2 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:3
configure lldp port 1:3 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:3 advertise vendor-specific dot1 vlan-name
configure lldp port 1:3 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:3 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:3 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:4
configure lldp port 1:4 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:4 advertise vendor-specific dot1 vlan-name
configure lldp port 1:4 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:4 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:4 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:5
configure lldp port 1:5 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:5 advertise vendor-specific dot1 vlan-name
configure lldp port 1:5 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:5 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:5 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:6
configure lldp port 1:6 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:6 advertise vendor-specific dot1 vlan-name
configure lldp port 1:6 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:6 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:6 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:7
configure lldp port 1:7 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:7 advertise vendor-specific dot1 vlan-name
configure lldp port 1:7 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:7 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:7 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:8
configure lldp port 1:8 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:8 advertise vendor-specific dot1 vlan-name
configure lldp port 1:8 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:8 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:8 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:9
configure lldp port 1:9 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:9 advertise vendor-specific dot1 vlan-name
configure lldp port 1:9 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:9 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:9 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:10
configure lldp port 1:10 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:10 advertise vendor-specific dot1 vlan-name
configure lldp port 1:10 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:10 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:10 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:11
configure lldp port 1:11 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:11 advertise vendor-specific dot1 vlan-name
configure lldp port 1:11 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:11 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:11 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:12
configure lldp port 1:12 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:12 advertise vendor-specific dot1 vlan-name
configure lldp port 1:12 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:12 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:12 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:13
configure lldp port 1:13 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:13 advertise vendor-specific dot1 vlan-name
configure lldp port 1:13 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:13 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:13 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:14
configure lldp port 1:14 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:14 advertise vendor-specific dot1 vlan-name
configure lldp port 1:14 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:14 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:14 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:15
configure lldp port 1:15 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:15 advertise vendor-specific dot1 vlan-name
configure lldp port 1:15 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:15 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:15 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:16
configure lldp port 1:16 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:16 advertise vendor-specific dot1 vlan-name
configure lldp port 1:16 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:16 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:16 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:17
configure lldp port 1:17 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:17 advertise vendor-specific dot1 vlan-name
configure lldp port 1:17 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:17 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:17 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:18
configure lldp port 1:18 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:18 advertise vendor-specific dot1 vlan-name
configure lldp port 1:18 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:18 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:18 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:19
configure lldp port 1:19 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:19 advertise vendor-specific dot1 vlan-name
configure lldp port 1:19 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:19 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:19 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:20
configure lldp port 1:20 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:20 advertise vendor-specific dot1 vlan-name
configure lldp port 1:20 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:20 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:20 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:21
configure lldp port 1:21 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:21 advertise vendor-specific dot1 vlan-name
configure lldp port 1:21 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:21 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:21 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:22
configure lldp port 1:22 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:22 advertise vendor-specific dot1 vlan-name
configure lldp port 1:22 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:22 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:22 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:23
configure lldp port 1:23 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:23 advertise vendor-specific dot1 vlan-name
configure lldp port 1:23 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:23 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:23 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:24
configure lldp port 1:24 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:24 advertise vendor-specific dot1 vlan-name
configure lldp port 1:24 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:24 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:24 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:25
configure lldp port 1:25 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:25 advertise vendor-specific dot1 vlan-name
configure lldp port 1:25 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:25 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:25 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:26
configure lldp port 1:26 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:26 advertise vendor-specific dot1 vlan-name
configure lldp port 1:26 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:26 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:26 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:27
configure lldp port 1:27 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:27 advertise vendor-specific dot1 vlan-name
configure lldp port 1:27 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:27 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:27 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:28
configure lldp port 1:28 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:28 advertise vendor-specific dot1 vlan-name
configure lldp port 1:28 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:28 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:28 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:29
configure lldp port 1:29 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:29 advertise vendor-specific dot1 vlan-name
configure lldp port 1:29 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:29 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:29 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:30
configure lldp port 1:30 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:30 advertise vendor-specific dot1 vlan-name
configure lldp port 1:30 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:30 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:30 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:31
configure lldp port 1:31 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:31 advertise vendor-specific dot1 vlan-name
configure lldp port 1:31 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:31 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:31 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:32
configure lldp port 1:32 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:32 advertise vendor-specific dot1 vlan-name
configure lldp port 1:32 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:32 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:32 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:33
configure lldp port 1:33 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:33 advertise vendor-specific dot1 vlan-name
configure lldp port 1:33 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:33 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:33 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:34
configure lldp port 1:34 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:34 advertise vendor-specific dot1 vlan-name
configure lldp port 1:34 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:34 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:34 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:35
configure lldp port 1:35 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:35 advertise vendor-specific dot1 vlan-name
configure lldp port 1:35 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:35 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:35 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:36
configure lldp port 1:36 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:36 advertise vendor-specific dot1 vlan-name
configure lldp port 1:36 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:36 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:36 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:37
configure lldp port 1:37 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:37 advertise vendor-specific dot1 vlan-name
configure lldp port 1:37 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:37 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:37 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:38
configure lldp port 1:38 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:38 advertise vendor-specific dot1 vlan-name
configure lldp port 1:38 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:38 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:38 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:39
configure lldp port 1:39 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:39 advertise vendor-specific dot1 vlan-name
configure lldp port 1:39 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:39 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:39 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:40
configure lldp port 1:40 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:40 advertise vendor-specific dot1 vlan-name
configure lldp port 1:40 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:40 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:40 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:41
configure lldp port 1:41 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:41 advertise vendor-specific dot1 vlan-name
configure lldp port 1:41 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:41 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:41 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:42
configure lldp port 1:42 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:42 advertise vendor-specific dot1 vlan-name
configure lldp port 1:42 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:42 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:42 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:43
configure lldp port 1:43 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:43 advertise vendor-specific dot1 vlan-name
configure lldp port 1:43 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:43 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:43 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:44
configure lldp port 1:44 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:44 advertise vendor-specific dot1 vlan-name
configure lldp port 1:44 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:44 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:44 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:45
configure lldp port 1:45 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:45 advertise vendor-specific dot1 vlan-name
configure lldp port 1:45 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:45 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:45 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:46
configure lldp port 1:46 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:46 advertise vendor-specific dot1 vlan-name
configure lldp port 1:46 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:46 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:46 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:47
configure lldp port 1:47 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:47 advertise vendor-specific dot1 vlan-name
configure lldp port 1:47 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:47 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:47 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:48
configure lldp port 1:48 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:48 advertise vendor-specific dot1 vlan-name
configure lldp port 1:48 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:48 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:48 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:49
configure lldp port 1:49 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:49 advertise vendor-specific dot1 vlan-name
configure lldp port 1:49 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:49 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:49 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 1:50
configure lldp port 1:50 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:50 advertise vendor-specific dot1 vlan-name
configure lldp port 1:50 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 1:50 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 1:50 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:1
configure lldp port 2:1 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:1 advertise vendor-specific dot1 vlan-name
configure lldp port 2:1 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:1 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:1 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:2
configure lldp port 2:2 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:2 advertise vendor-specific dot1 vlan-name
configure lldp port 2:2 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:2 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:2 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:3
configure lldp port 2:3 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:3 advertise vendor-specific dot1 vlan-name
configure lldp port 2:3 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:3 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:3 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:4
configure lldp port 2:4 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:4 advertise vendor-specific dot1 vlan-name
configure lldp port 2:4 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:4 advertise vendor-specific avaya-extreme file-server 192.168.100.254
 configure lldp port 2:4 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:5
configure lldp port 2:5 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:5 advertise vendor-specific dot1 vlan-name
configure lldp port 2:5 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:5 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:5 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:6
configure lldp port 2:6 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:6 advertise vendor-specific dot1 vlan-name
configure lldp port 2:6 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:6 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:6 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:7
configure lldp port 2:7 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:7 advertise vendor-specific dot1 vlan-name
configure lldp port 2:7 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:7 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:7 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:8
configure lldp port 2:8 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:8 advertise vendor-specific dot1 vlan-name
configure lldp port 2:8 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:8 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:8 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:9
configure lldp port 2:9 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:9 advertise vendor-specific dot1 vlan-name
configure lldp port 2:9 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:9 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:9 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:10
configure lldp port 2:10 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:10 advertise vendor-specific dot1 vlan-name
configure lldp port 2:10 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:10 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:10 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:11
configure lldp port 2:11 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:11 advertise vendor-specific dot1 vlan-name
configure lldp port 2:11 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:11 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:11 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:12
configure lldp port 2:12 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:12 advertise vendor-specific dot1 vlan-name
configure lldp port 2:12 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:12 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:12 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:13
configure lldp port 2:13 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:13 advertise vendor-specific dot1 vlan-name
configure lldp port 2:13 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:13 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:13 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:14
configure lldp port 2:14 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:14 advertise vendor-specific dot1 vlan-name
configure lldp port 2:14 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:14 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:14 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:15
configure lldp port 2:15 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:15 advertise vendor-specific dot1 vlan-name
configure lldp port 2:15 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:15 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:15 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:16
configure lldp port 2:16 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:16 advertise vendor-specific dot1 vlan-name
configure lldp port 2:16 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:16 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:16 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:17
configure lldp port 2:17 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:17 advertise vendor-specific dot1 vlan-name
configure lldp port 2:17 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:17 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:17 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:18
configure lldp port 2:18 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:18 advertise vendor-specific dot1 vlan-name
configure lldp port 2:18 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:18 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:18 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:19
configure lldp port 2:19 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:19 advertise vendor-specific dot1 vlan-name
configure lldp port 2:19 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:19 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:19 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:20
configure lldp port 2:20 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:20 advertise vendor-specific dot1 vlan-name
configure lldp port 2:20 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:20 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:20 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:21
configure lldp port 2:21 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:21 advertise vendor-specific dot1 vlan-name
configure lldp port 2:21 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:21 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:21 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:22
configure lldp port 2:22 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:22 advertise vendor-specific dot1 vlan-name
configure lldp port 2:22 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:22 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:22 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:23
configure lldp port 2:23 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:23 advertise vendor-specific dot1 vlan-name
configure lldp port 2:23 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:23 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:23 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:24
configure lldp port 2:24 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:24 advertise vendor-specific dot1 vlan-name
configure lldp port 2:24 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:24 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:24 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:25
configure lldp port 2:25 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:25 advertise vendor-specific dot1 vlan-name
configure lldp port 2:25 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:25 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:25 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:26
configure lldp port 2:26 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:26 advertise vendor-specific dot1 vlan-name
configure lldp port 2:26 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:26 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:26 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:27
configure lldp port 2:27 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:27 advertise vendor-specific dot1 vlan-name
configure lldp port 2:27 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:27 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:27 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:28
configure lldp port 2:28 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:28 advertise vendor-specific dot1 vlan-name
configure lldp port 2:28 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:28 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:28 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:29
configure lldp port 2:29 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:29 advertise vendor-specific dot1 vlan-name
configure lldp port 2:29 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:29 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:29 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:30
configure lldp port 2:30 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:30 advertise vendor-specific dot1 vlan-name
configure lldp port 2:30 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:30 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:30 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:31
configure lldp port 2:31 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:31 advertise vendor-specific dot1 vlan-name
configure lldp port 2:31 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:31 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:31 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:32
configure lldp port 2:32 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:32 advertise vendor-specific dot1 vlan-name
configure lldp port 2:32 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:32 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:32 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:33
configure lldp port 2:33 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:33 advertise vendor-specific dot1 vlan-name
configure lldp port 2:33 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:33 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:33 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:34
configure lldp port 2:34 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:34 advertise vendor-specific dot1 vlan-name
configure lldp port 2:34 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:34 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:34 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:35
configure lldp port 2:35 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:35 advertise vendor-specific dot1 vlan-name
configure lldp port 2:35 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:35 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:35 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:36
configure lldp port 2:36 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:36 advertise vendor-specific dot1 vlan-name
configure lldp port 2:36 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:36 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:36 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:37
configure lldp port 2:37 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:37 advertise vendor-specific dot1 vlan-name
configure lldp port 2:37 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:37 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:37 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:38
configure lldp port 2:38 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:38 advertise vendor-specific dot1 vlan-name
configure lldp port 2:38 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:38 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:38 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:39
configure lldp port 2:39 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:39 advertise vendor-specific dot1 vlan-name
configure lldp port 2:39 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:39 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:39 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:40
configure lldp port 2:40 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:40 advertise vendor-specific dot1 vlan-name
configure lldp port 2:40 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:40 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:40 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:41
configure lldp port 2:41 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:41 advertise vendor-specific dot1 vlan-name
configure lldp port 2:41 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:41 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:41 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:42
configure lldp port 2:42 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:42 advertise vendor-specific dot1 vlan-name
configure lldp port 2:42 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:42 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:42 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:43
configure lldp port 2:43 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:43 advertise vendor-specific dot1 vlan-name
configure lldp port 2:43 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:43 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:43 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:44
configure lldp port 2:44 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:44 advertise vendor-specific dot1 vlan-name
configure lldp port 2:44 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:44 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:44 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:45
configure lldp port 2:45 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:45 advertise vendor-specific dot1 vlan-name
configure lldp port 2:45 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:45 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:45 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:46
configure lldp port 2:46 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:46 advertise vendor-specific dot1 vlan-name
configure lldp port 2:46 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:46 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:46 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:47
configure lldp port 2:47 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:47 advertise vendor-specific dot1 vlan-name
 configure lldp port 2:47 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:47 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:47 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:48
configure lldp port 2:48 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:48 advertise vendor-specific dot1 vlan-name
configure lldp port 2:48 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:48 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:48 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:49
configure lldp port 2:49 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:49 advertise vendor-specific dot1 vlan-name
configure lldp port 2:49 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:49 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:49 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 2:50
configure lldp port 2:50 advertise vendor-specific dot1 port-vlan-id
configure lldp port 2:50 advertise vendor-specific dot1 vlan-name
configure lldp port 2:50 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 2:50 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 2:50 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:1
configure lldp port 3:1 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:1 advertise vendor-specific dot1 vlan-name
configure lldp port 3:1 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:1 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:1 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:2
configure lldp port 3:2 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:2 advertise vendor-specific dot1 vlan-name
configure lldp port 3:2 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:2 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:2 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:3
configure lldp port 3:3 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:3 advertise vendor-specific dot1 vlan-name
configure lldp port 3:3 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:3 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:3 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:4
configure lldp port 3:4 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:4 advertise vendor-specific dot1 vlan-name
configure lldp port 3:4 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:4 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:4 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:5
configure lldp port 3:5 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:5 advertise vendor-specific dot1 vlan-name
configure lldp port 3:5 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:5 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:5 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:6
configure lldp port 3:6 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:6 advertise vendor-specific dot1 vlan-name
configure lldp port 3:6 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:6 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:6 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:7
configure lldp port 3:7 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:7 advertise vendor-specific dot1 vlan-name
configure lldp port 3:7 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:7 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:7 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:8
configure lldp port 3:8 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:8 advertise vendor-specific dot1 vlan-name
configure lldp port 3:8 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:8 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:8 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:9
configure lldp port 3:9 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:9 advertise vendor-specific dot1 vlan-name
configure lldp port 3:9 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:9 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:9 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:10
configure lldp port 3:10 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:10 advertise vendor-specific dot1 vlan-name
configure lldp port 3:10 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:10 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:10 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:11
configure lldp port 3:11 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:11 advertise vendor-specific dot1 vlan-name
configure lldp port 3:11 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:11 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:11 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:12
configure lldp port 3:12 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:12 advertise vendor-specific dot1 vlan-name
configure lldp port 3:12 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:12 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:12 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:13
configure lldp port 3:13 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:13 advertise vendor-specific dot1 vlan-name
configure lldp port 3:13 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:13 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:13 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:14
configure lldp port 3:14 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:14 advertise vendor-specific dot1 vlan-name
configure lldp port 3:14 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:14 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:14 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:15
configure lldp port 3:15 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:15 advertise vendor-specific dot1 vlan-name
configure lldp port 3:15 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:15 advertise vendor-specific avaya -extreme file-server 192.168.100.254
configure lldp port 3:15 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:16
configure lldp port 3:16 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:16 advertise vendor-specific dot1 vlan-name
configure lldp port 3:16 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:16 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:16 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:17
configure lldp port 3:17 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:17 advertise vendor-specific dot1 vlan-name
configure lldp port 3:17 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:17 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:17 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:18
configure lldp port 3:18 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:18 advertise vendor-specific dot1 vlan-name
configure lldp port 3:18 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:18 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:18 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:19
configure lldp port 3:19 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:19 advertise vendor-specific dot1 vlan-name
configure lldp port 3:19 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:19 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:19 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:20
configure lldp port 3:20 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:20 advertise vendor-specific dot1 vlan-name
configure lldp port 3:20 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:20 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:20 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:21
configure lldp port 3:21 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:21 advertise vendor-specific dot1 vlan-name
configure lldp port 3:21 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:21 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:21 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:22
configure lldp port 3:22 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:22 advertise vendor-specific dot1 vlan-name
configure lldp port 3:22 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:22 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:22 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:23
configure lldp port 3:23 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:23 advertise vendor-specific dot1 vlan-name
configure lldp port 3:23 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:23 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:23 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:24
configure lldp port 3:24 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:24 advertise vendor-specific dot1 vlan-name
configure lldp port 3:24 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:24 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:24 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:25
configure lldp port 3:25 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:25 advertise vendor-specific dot1 vlan-name
configure lldp port 3:25 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:25 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:25 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:26
configure lldp port 3:26 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:26 advertise vendor-specific dot1 vlan-name
configure lldp port 3:26 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:26 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:26 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:27
configure lldp port 3:27 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:27 advertise vendor-specific dot1 vlan-name
configure lldp port 3:27 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:27 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:27 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:28
configure lldp port 3:28 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:28 advertise vendor-specific dot1 vlan-name
configure lldp port 3:28 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:28 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:28 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:29
configure lldp port 3:29 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:29 advertise vendor-specific dot1 vlan-name
configure lldp port 3:29 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:29 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:29 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:30
configure lldp port 3:30 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:30 advertise vendor-specific dot1 vlan-name
configure lldp port 3:30 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:30 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:30 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:31
configure lldp port 3:31 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:31 advertise vendor-specific dot1 vlan-name
configure lldp port 3:31 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:31 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:31 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:32
configure lldp port 3:32 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:32 advertise vendor-specific dot1 vlan-name
configure lldp port 3:32 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:32 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:32 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:33
configure lldp port 3:33 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:33 advertise vendor-specific dot1 vlan-name
configure lldp port 3:33 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:33 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:33 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:34
configure lldp port 3:34 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:34 advertise vendor-specific dot1 vlan-name
configure lldp port 3:34 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:34 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:34 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:35
configure lldp port 3:35 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:35 advertise vendor-specific dot1 vlan-name
configure lldp port 3:35 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:35 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:35 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:36
configure lldp port 3:36 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:36 advertise vendor-specific dot1 vlan-name
configure lldp port 3:36 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:36 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:36 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:37
configure lldp port 3:37 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:37 advertise vendor-specific dot1 vlan-name
configure lldp port 3:37 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:37 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:37 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:38
configure lldp port 3:38 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:38 advertise vendor-specific dot1 vlan-name
configure lldp port 3:38 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:38 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:38 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:39
configure lldp port 3:39 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:39 advertise vendor-specific dot1 vlan-name
configure lldp port 3:39 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:39 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:39 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:40
configure lldp port 3:40 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:40 advertise vendor-specific dot1 vlan-name
configure lldp port 3:40 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:40 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:40 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:41
configure lldp port 3:41 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:41 advertise vendor-specific dot1 vlan-name
configure lldp port 3:41 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:41 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:41 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:42
configure lldp port 3:42 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:42 advertise vendor-specific dot1 vlan-name
configure lldp port 3:42 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:42 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:42 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:43
configure lldp port 3:43 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:43 advertise vendor-specific dot1 vlan-name
configure lldp port 3:43 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:43 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:43 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:44
configure lldp port 3:44 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:44 advertise vendor-specific dot1 vlan-name
configure lldp port 3:44 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:44 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:44 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:45
configure lldp port 3:45 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:45 advertise vendor-specific dot1 vlan-name
configure lldp port 3:45 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:45 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:45 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:46
configure lldp port 3:46 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:46 advertise vendor-specific dot1 vlan-name
configure lldp port 3:46 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:46 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:46 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:47
configure lldp port 3:47 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:47 advertise vendor-specific dot1 vlan-name
configure lldp port 3:47 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:47 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:47 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:48
configure lldp port 3:48 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:48 advertise vendor-specific dot1 vlan-name
configure lldp port 3:48 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:48 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:48 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:49
configure lldp port 3:49 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:49 advertise vendor-specific dot1 vlan-name
configure lldp port 3:49 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:49 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:49 advertise vendor-specific avaya-extreme dot1q-framing auto
enable lldp ports 3:50
configure lldp port 3:50 advertise vendor-specific dot1 port-vlan-id
configure lldp port 3:50 advertise vendor-specific dot1 vlan-name
configure lldp port 3:50 advertise vendor-specific avaya-extreme call-server 192.168.100.254
configure lldp port 3:50 advertise vendor-specific avaya-extreme file-server 192.168.100.254
configure lldp port 3:50 advertise vendor-specific avaya-extreme dot1q-framing auto
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
configure sntp-client primary 192.168.0.151 vr VR-Default
configure bootprelay add 192.168.0.17 vr VR-Default
enable bootprelay vlan Default
enable bootprelay vlan VLAN11
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
configure snmpv3 add target-addr v1v2cNotifyTAddr1 param v1v2cNotifyParam1 ipaddress 192.168.0.72 transport-port 10550 f
rom 192.168.0.1 tag-list defaultNotify
configure snmpv3 add target-params v1v2cNotifyParam1 user v1v2cNotifyUser1 mp-model snmpv2c sec-model snmpv2c sec-level
noauth
# Module stp configuration.
configure mstp region 020496524a09
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
enable stpd s0 auto-bind vlan Default
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
enable web http
# Module vmt configuration.
# Module vsm configuration.
Photo of IT-SA
IT-SA
  • 226 Points 100 badge 2x thumb
Posted 1 month ago
Photo of Eric Burke
Eric Burke
  • 3,082 Points 3k badge 2x thumb
What's routing between VLAN's? I see all of your VLAN's, but I don't see anything routing between them. Do you have a firewall or some other device in place?
Photo of IT-SA
IT-SA
The switch that I uploaded should be the device doing routing.
Photo of Eric Burke
Eric Burke
  • 3,012 Points 3k badge 2x thumb
Sorry about that - misread the configs (those ipforwarding commands hide in the middle of a bunch of stuff). Let me re-read :-)...
Photo of Eric Burke
Eric Burke
Stupid question - the devices are untagged in V11, correct? Here's the list of items you show there: 1:41, 2:21, 2:30, 3:7. Try dumping a "show port vlan" and make sure that the devices needing to be routed are untagged. At first glance, it looks okay. Issue a "show ipconfig" and "show iproute" and make sure nothing jumps out there. You can also dump the arp cache on a PC (set IP manually first) and make sure the MAC of the DFGW is actually the extreme. Same on the DHCP server.
(Edited)
Photo of IT-SA
IT-SA
Yeah, those are the ports I have been playing with trying to get it working.
The ports are untagged.
Photo of IT-SA
IT-SA
show iproute
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#s   Default Route      192.168.0.2     1    UG---S-um--f- Default    5d:22h:16m:30s
 d   10.90.0.0/29       10.90.0.1       1    -------um---- replication 5d:22h:16m:43s
#d   192.168.0.0/24     192.168.0.1     1    U------um--f- Default    5d:22h:16m:43s
#d   192.168.11.0/24    192.168.11.1    1    U------um--f- VLAN11     5d:6h:1m:47s
#d   192.168.100.0/24   192.168.100.1   1    U------um--f- VOICE      5d:22h:16m:43s
Origin(Ori): (b) BlackHole, (be) EBGP, (bg) BGP, (bi) IBGP, (bo) BOOTP
       (ct) CBT, (d) Direct, (df) DownIF, (dv) DVMRP, (e1) ISISL1Ext
       (e2) ISISL2Ext, (h) Hardcoded, (i) ICMP, (i1) ISISL1 (i2) ISISL2
       (is) ISIS, (mb) MBGP, (mbe) MBGPExt, (mbi) MBGPInter, (mp) MPLS Lsp
       (mo) MOSPF (o) OSPF, (o1) OSPFExt1, (o2) OSPFExt2
       (oa) OSPFIntra, (oe) OSPFAsExt, (or) OSPFInter, (pd) PIM-DM, (ps) PIM-SM
       (r) RIP, (ra) RtAdvrt, (s) Static, (sv) SLB_VIP, (un) UnKnown
       (*) Preferred unicast route (@) Preferred multicast route
       (#) Preferred unicast and multicast route
Flags: (B) BlackHole, (b) BFD protection requested, (c) Compressed, (D) Dynamic
       (f) Provided to FIB, (G) Gateway, (H) Host Route, (L) Matching LDP LSP
       (l) Calculated LDP LSP, (3) L3VPN Route, (m) Multicast, (P) LPM-routing
       (p) BFD protection active, (R) Modified, (S) Static, (s) Static LSP
       (T) Matching RSVP-TE LSP, (t) Calculated RSVP-TE LSP, (u) Unicast, (U) Up
MPLS Label: (S) Bottom of Label Stack
Mask distribution:
     1 default routes                3 routes at length 24
     1 routes at length 29
Route Origin distribution:
     4 routes from Direct               1 routes from Static
Total number of routes = 5
Total number of compressed routes = 0
Photo of Robert Cummins
Robert Cummins
  • 452 Points 250 badge 2x thumb
Did you enable IP forwarding on the VLAN?   Do a 'show VLAN vlan11' and check
Photo of IT-SA
IT-SA
VLAN Interface with name VLAN11 created by user
        Admin State:    Enabled         Tagging:        802.1Q Tag 11
        Description:    None
        Virtual router: VR-Default
        IPv4 Forwarding: Enabled
        Primary IP    : 192.168.11.1/24
        IPv6 Forwarding: Disabled
        IPv6:           None
        STPD:           None
        Protocol:       Match all unfiltered protocols
        Loopback:       Disabled
        NetLogin:       Disabled
        QosProfile:     None configured
        Egress Rate Limit Designated Port: None configured
        Flood Rate Limit QosProfile:       None configured
        Ports:   4.       (Number of active ports=3)
           Untag:   *1:41,   2:21,  *2:30,   *3:7
        Flags:    (*) Active, (!) Disabled, (g) Load Sharing port
                  (b) Port blocked on the vlan, (m) Mac-Based port
                  (a) Egress traffic allowed for NetLogin
                  (u) Egress traffic unallowed for NetLogin
                  (t) Translate VLAN tag for Private-VLAN
                  (s) Private-VLAN System Port, (L) Loopback port
                  (e) Private-VLAN End Point Port
                  (x) VMAN Tag Translated port
                  (G) Multi-switch LAG Group port
Photo of IT-SA
IT-SA
I should mention that ports 1:41 and 2:30 are currently working. I thought I had it figured out last week but all the other ports I try to enable as VLAN11 seems to fail to pull DHCP IP.
I can ping them from a VLAN1 PC too.
(Edited)
Photo of IT-SA
IT-SA
I really don't think so but you never know. I checked the security log on the switch and didn't see anything out of line. Just me and my coworker IPs showed up.
Photo of Eric Burke
Eric Burke
In your first port comparison you sent 41 and 13, then said you had the wrong port. You resent 13 making me think that was the wrong one, but in the second example it had different vlan's. The first time it was not even on V11. Was 41 the working one or 2:13?
Photo of IT-SA
IT-SA
Sorry, the first time I sent 2:13 I didn't have it setup for VLAN11. It was the port in my office that I was testing. I thought I had left it on VLAN11. I reconfigured it and sent the new info back to you.
Photo of IT-SA
IT-SA
1:41 is a port in a different office that is currently working. I've deleted it's DHCP entry and it was able to repull. I can also ping that PC from VLAN1.
Photo of Eric Burke
Eric Burke
okay, how a bout a "sho fdb" and a "sho fdb port x:x" (big one to see general list, other to specifically see ports like 2:13 and 1:41. Should see MAC in proper VLAN for connected device(s).
Robert Cummins
Other than not supporting IPv6 forwarding vlan11 looks okay.
Are the PCs on the default VLAN able to ping systems on the voice or replication vlans?   Can systems on voice/replication reach machines on vlan11?    I never configure VLAN 1 so I don't know if it is a good practice do what you're doing here.
Photo of IT-SA
IT-SA
Yes, the PCs on default VLAN can ping other devices on other VLANs. I did not create this mess lol.
Robert Cummins
169.254.0.0/16 are IPv4 link-local addresses that are assigned when a DHCP client does not get a DHCP response.
Robert Cummins
Is the problem only getting a DHCP response on the VLAN?   You said two ports are working but "other" ports fail to get DHCP replies.   I'm trying to make sure this is not a dhcp-relay problem and that any statically configured IP system works.
Yeah,  I thought I remembered that each VLAN needs to have DHCP relay enabled.   I'll go back and look at your config - is 'enable bootprelay ipv4 VLAN VLAN11' set?  We'll see....
Yep, you have it enabled....<thinking...>
(Edited)
Photo of Eric Burke
Eric Burke
I was thinking that too initially. If you static two devices on V11, can they ping eachother?
Photo of IT-SA
IT-SA
So, I thought 2:13 was still setup for VLAN11 earlier. So when I tried doing static IP, it didn't work. Now that it is setup for VLAN11, it does work with a static IP so it for sure is something with DHCP. But what is it and why does it work on a couple of the ports.
Photo of Eric Burke
Eric Burke
IMO VLAN's on Extreme are some of the easiest to work with. No funky PVID's or weird terms, just tagged or untagged membership - that's it. Multiple and it's a trunk, one untagged and it's an access port. I don't often route in the switch unless I need a small /30 for an outside ISP or something like that so in my case I'm not usually using Bootprelay. It looked like you had a relay on the default vlan which is native to most of your users, so I don't think you need that set. Depending on your server, you could also tag V11 into that adapter, trunk the port with both def/11 and essentially drop DHCP on that subinterface directly (getting rid of relay).
Robert Cummins
Okay, is your dhcp server handing out addresses based on MAC address or does it have a pool of addresses to hand out?   Also, is the DHCP server configured to support the network 192.168.11.0/24?  (Did I read that right in the top of your config?   I thought it was 192.168.something_else.1/24)
Photo of Eric Burke
Eric Burke
I think I see it... Add the IP address of the relay server to your vlan based bootprelay commands (in addition to the global setting).
config bootprelay vlan11 add x.x.x.x
(Edited)
Photo of Eric Burke
Eric Burke
enable bootprelay x.x.x.x enables it globally, enable bootprelay vlan v11 enables for that vlan, config bootprelay v11 add x.x.x.x sets up the relay agent for that newly enabled vlan.
Photo of IT-SA
IT-SA
I just added the configure bootprelay vlan vlan11 add 192.168.0.17
Doesn't seem to help 2:13 getting an IP.
Photo of Eric Burke
Eric Burke
Unconfig that and instead add it to default - I think I read it backwards. Rob's example does not show it but it looks like the docs show it. The vr-default is just the router instance that the vlan's live in. It reads like it needs to have the vlan passed into the config where the server lives too.
Photo of IT-SA
IT-SA
Just did that and same. Going to remove and call it a night. I'll resume tomorrow afternoon. Thank you for all your help!!!
Robert Cummins
Hmm... that's not how my router is configured:
configure bootprelay add 10.80.195.242 vr VR-Default
configure bootprelay add 10.80.195.247 vr VR-Default
configure bootprelay add 10.80.222.70 vr VR-Default
enable bootprelay ipv4 vlan client2247
enable bootprelay ipv4 vlan ISL-to-Nimbula
enable bootprelay ipv4 vlan manmgt2247
enable bootprelay ipv4 VLAN net2247
enable bootprelay ipv4 vlan storage2247
Photo of Eric Burke
Eric Burke
Maybe I'm misreading it. That's how it looked from the sample.
Robert Cummins
Statically configured IPs seem to route correctly but clients needing a DHCP response seem to not get it.   The VLAN and bootprelay seem to be configured properly so I would check the dhcp server to make sure it is still serving addresses for 192.168.11.0/24.   If possible, I'd run a tcpdump on the DHCP server and check for DHCP Request packets coming from 192.168.11.1 and if so, does the server send a DCHP ACK packet back.   If the server has a log file then check it.  If that works then the DHCP server is not the issue and you know that bootprelay is not the issue.   If the packet never arrives then it still something with the configuration.
Photo of IT-SA
IT-SA
I will dig into this tomorrow. I am going to call it a night. I appreciate all of your and Eric's help tonight. We are getting closer!
Photo of Eric Burke
Eric Burke
I think so. There are some other basic things like pinging the DHCP from an interface based IP in V11 that will show if the switch can get to the DHCP server by itself. In addition, I found a link that describes the difference between the global and vlan-specific DHCP server entries. It's toward the bottom of this post when you're back up and looking at it with fresh eyes... It still sounds like you might have a l2 problem if your devices can't ping when statically assigned in that vlan.  Goodnight.
https://community.extremenetworks.com/extreme/topics/how-to-configure-dhcp-server-in-extreme-switch-...
Photo of IT-SA
IT-SA
On the ports that work, I am getting DHCP requests packets on the server. On 2:13, nothing ever shows up in the wireshark.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,886 Points 10k badge 2x thumb
Port 2:13 is not in VLAN11 according to the config posted in the initial question and according to the "show vlan VLAN11" output.
Please verify the VLAN configuration for that port, e.g. using "show port 2:13 information detail," and post the output.
Thanks,
Erik
Photo of IT-SA
IT-SA
        Description:    None
        IPv6:           None
        STPD:           None
        Loopback:       Disabled
        NetLogin:       Disabled
        Ports:   5.       (Number of active ports=5)
           Untag:   *1:41,  *2:13,  *2:21,  *2:30,   *3:7
