Interface statistics IP-Fix collection performance
  • Question
  • Updated 3 years ago
  • Answered
Does collecting Interface stats and or IP flows from switches effect switch performance? I am using Netsight to collect data on my uplinks. I am just wondering if I am hurting switch performance.
Photo of GCIT_Support
GCIT_Support
  • 510 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
As I believe I answered in one of your prior posts, there is a fixed CPU overhead when you enable IP-FIX.  Because IP-FIX is performed by the switching ASIC the actual generation of flows is done in hardware but the processing of the flows to the collector is a process in XOS.  The XOS process can generate some CPU overhead but that overhead will not effect overall switch packet processing unless there is a lot of slow-path traffic.
