Invalid input detected at '^' marker. when portforwarding
  • Question
  • Updated 1 year ago
  • Answered
I am new to setting up a network, so this might be a newbe issue.
I have created a new vlan, and would like to enable portforwarding, but when I try to forward:
 enable ipforwarding vlan v10
I get an error:
%% Invalid input detected at '^' marker.
The marker is underneath the "f" character.
I have followed this guide:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-inter-VLAN-routing-in-EXOS
I am using the console input.
We have a Cisco ME3400-2CS with 5 IPs, connected to the summit x350-48t switch. We would like to forward all trafic from one of the IPs to our server, which is on the before created vlan.
Best regards
Dennis
Photo of Dennis Christensen
Dennis Christensen
  • 92 Points 75 badge 2x thumb
  • thankful
Posted 1 year ago
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,500 Points 3k badge 2x thumb
Hi Dennis,
The X350 doesn't support ip forwarding.
Thanks
Brad
Dennis Christensen
Oh thanks!
Do you have en idea how I can delegate delegate trafic from one of my IPs to a vlan without forwarding, or isn't it possible?
Thanks again!
Hi Dennis,
Can you tell me more? I'm not sure exactly what you're trying to do.
Thanks
Brad
Dennis Christensen
I am trying to setup a network where I have a server which needs to be reachable from outside. Then I have a office network, containing a wifi router and some PCs connected through the switch.
I would like if I could (forward) one or more of my static IP to the server. And create a vlan of the office PC, and the two vlans server and office should be reachable from one another.
Again this is my first time trying to setup a more complex system than my home network. I am a software developer with decent *unix experience, but this i a bit out of my reach.
It seems that all the guides I've found involves ipforwarding.
Thanks!
(Edited)
  • 3,460 Points 3k badge 2x thumb
Hi Dennis
Shoot What you're describing is ipforwarding (or routing) and isn't supported on the x350. The x350 was designed as a purely later 2 switch, with an IP address on it for management. I'm sorry
