IP address issue for end users
  • Question
  • Updated 3 years ago
  • Answered
We added 22 access points to existing network. Setup is like this :
10 ap's are part of vlan 80 in building-1
Remaining 12 ap's part of vlan 81 in building-2
Users connecting to ap's ( vlan 80 )should get IP from vlan 90
Users connecting to ap's (vlan 81) should get IP from vlan 91
Now the issue is when we are in building-1 end user is getting IP , when he is moving to building 2 user not getting IP, but few users at building-2 are getting IP.
As a resolution I have done the below:
Grouped building-1 ap's and users in a single vlan 80
Grouped building-2 ap's and users in a single vlan 81
Now it seems to be better , but not sure is this correct resolution can anyone guide me.
Photo of Saiprasad Rao Rapolu
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,328 Points 50k badge 2x thumb
it's function as designed, the feature is called "Permit Inter-WLAN Service Roaming".
Here a post that explains it...
https://community.extremenetworks.com/extreme/topics/wireless_location_issues
https://gtacknowledge.extremenetworks.com/articles/Solution/Client-is-not-getting-a-new-Role-and-IP-...
Just turn of "Permit Inter-WLAN Service Roaming" in the advanced option of the WLAN Service and the clients will use the VLAN in this building.
-Ron
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
Are you using the same SSID for both services? Try disabling Inter-WLAN Service Roaming in the advance tab on each WLAN-Service.
Photo of Doug Hyde
Also you should be aware that we are at the mercy of the client device to do a clean dhcp renew when flipping subnets...
Issue resolved getting IP address, but not able to access internet.   In Building-1 got ip and able to access internet but when moved to building-2 got Building-2 IP but not able to access internet.
Photo of Doug Hyde
When you are connected to the network that does not work, can you ping the clients default gateway? Does it reply?
yes, i am able to ping default gateway of the end user vlan
Photo of Doug Hyde
How about DNS resolving, is that working too? Try doing an nslookup on something. Also are there any policy rules that are different on one VNS versus the other? If the policy on the controller looks good and you are making it to the default gateway, chances are the issues are not with the wireless....
(Edited)
We are using public DNS, end user gets public DNS, name resolution is not happening..... There are no different policies....... I again checked what I found is few users are able to browse internet and few cannot. In building-2 , even I two was able to access internet when I went to building-2 to cross check again. Totally strange..
(Edited)
