IP controller string
  • Question
  • Updated 2 years ago
  • Answered
Hello,
we use 6522 and a few older models which all use option 191 with ASCII for WINGAP or Motorola etc etc
We are now using the new 7522 APs but they aren't going to obtain there config. Please can you confirm the ip controller address for the 7522s should they have for example
0000 45 78 74 72 65 6D 65 41 Extreme
0008 50 20 41 50 37 35 32 32 AP7522
thanks
Photo of Michael Wright
Michael Wright
  • 324 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,608 Points 10k badge 2x thumb
The format of option 191 should be 'pool1=<controller_IP>'. For example, if the controller's IP is 10.1.1.1, it would be 'pool1=10.1.1.1'.
Michael Wright
I'm aware of the string, that information has remained the same but i need to know if the classes have changed?
  • 13,606 Points 10k badge 2x thumb
Sorry, misunderstood your question. Looks like Christoph got you the correct answer below.
Photo of Christoph S.
Christoph S., Employee
  • 3,684 Points 3k badge 2x thumb
Hello Michael,
Please find herein the new ASCII VCI codes as of WiNG 5.7.x:
Those can be found in the release notes as well:
http://documentation.extremenetworks.com/release_notes/WiNG/9035063_WiNG_v5_8_6_Release_Notes.pdf
(Edited)
