ip forwarding issue
ip forwarding issue
Marlon
New Contributor III
we have summit x460 configured with 3 vlans. ipforwarding is disabled to all vlans but were still able to ping from one vlan to another. please see below the screenshot
we also have pc directly connected to vlan server and still can reached the other vlans even the ipforwarding is disabled. below is the screenshot
below are the iproutes from switch
is this correct? I am expecting if ipforwarding is disable vlan will not communicate with each other like layer 2.
thanks
12 REPLIES 12
Drew_C
Valued Contributor III
Hi Marlon, do you still need assistance with this? It may be best to open a case with GTAC if this hasn't been resolved yet.
Drew_C
I think so too, but I wanted to try to be sure. Lots of loose ends around here that I'm trying to tie up 🙂
in my opinion Matthew gave the answer on that topic.
JeremyClarkson
Marlon can you confirm please.
