ip helper-address on Extreme
  • 3
  • 2
  • Question
  • Updated 2 years ago
  • Answered
Coming from a HP Procurve world, we could have 'ip helper-address' settings for each VLAN.  How can I have a production VLAN have a different DHCP server from a Guest VLAN in EXOS?
Here's my procurve settings:
vlan 200
  name "VLAN200"
  ip helper-address 192.168.200.12
vlan 500
  name "VLAN500"
  ip helper-address 172.16.0.1
What would the equivalent of this look like on EXOS?
Thanks,
Bruce
Photo of Bruce Garlock
Bruce Garlock
  • 612 Points 500 badge 2x thumb
Posted 2 years ago
  • 3
  • 2
Photo of Drew C.
Drew C., Community Manager
  • 37,322 Points 20k badge 2x thumb
(Edited)
Photo of David Coglianese
David Coglianese, Embassador
  • 5,944 Points 5k badge 2x thumb
Configure bootp relay for your helper address.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
configure bootprelay add <server IP> vr vr-default
enable bootprelay vr vr-default vlan <name of vlan>
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
The article says this as well but you need to make sure you enable bootprelay on the VLAN the server sits on as well. If the discover needs to be routed to get to this VLAN enable bootprelay on the egress VLAN
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Bruce, just to add on to what everyone else already said, if you want to send DHCP traffic from one vlan to a specific DHCP server, you can specify the vlan when adding the server in bootprelay. For example:
en bootprelay vlan v1
en bootprelay vlan v2
conf bootprelay vlan v1 add 1.1.1.2
conf bootprelay vlan v2 add 2.2.2.2
Bruce Garlock
This is exactly what I was looking for!  Many thanks!!
