IP MTU on EX switch
  • Question
  • Updated 3 years ago
  • Answered
Hi everybody,
I want my switch to pass IP packet of 2000 bytes it generated.
Here is my config:
create vlan NEE
config vlan NEE tag 45
config vlan NEE ipaddress 199.199.199.1 255.255.255.252
configure ip-mtu 2000 Vlan NEE
All ports are enabled for jumbo frames.
Am is missing anything as far as this switch is concerned ?
Thanks.
Photo of zeeshan qadir
zeeshan qadir
  • 266 Points 250 badge 2x thumb
Posted 3 years ago
Photo of French, Luke
French, Luke, Employee
  • 754 Points 500 badge 2x thumb
(Edited)
Photo of Thomas, Ken
Thomas, Ken, Alum
  • 4,368 Points 4k badge 2x thumb
Zeeshan, let us know if the gtac kb article provided answers your question or if you have any follow questions
zeeshan qadir
Hi Thomas,
This is what I am seeing:( to the best of my memory, I do not have access to the switch right now)
vlan Zee ipaddress 199.199.199.1/30
config ip-mtu 2000 vlan ZEE
enable jumbo frames ports all
Now if i issue ping from the switch to 199.199.199.2  size 1800 ( neighboring device)with DF bit set, I get following:
Packets is to large, DF bit set, can not fragment it  reply from 199.199.199.1
I want to be able to generate such packets so we can check if service provider is allowing such packet across the cloud without fragmentation.
Thanks
(Edited)
Photo of Chad Smith
Chad Smith, Alum
  • 5,660 Points 5k badge 2x thumb
Zeeshan,
The configuration changes you have made seem to be correct.  Were you able to make any progress on this?
Are the switch and 199.199.199.2 directly connected?
