IP phones hang at discover mode , is configuring lldp on extreme switch mandatory ?
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
IP phones (avaya) hang at discover mode and unable to communicate to call manager server , is configuring lldp on extreme switch access ports mandatory ?
Are below lines enough:
enable lldp ports
configure lldp port advertise vendor-specific med capabilities
configure lldp port advertise vendor-specific dot1 vlan-name vlan
configure lldp transmit-interval 5<br>
Are above commands for access ports only on which ip phones connect?
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Here is what I use:  Works like a charm.
configure lldp port 1:1 advertise port-description
configure lldp port 1:1 advertise system-name
configure lldp port 1:1 advertise system-capabilities
configure lldp port 1:1 advertise management-address
configure lldp port 1:1 advertise vendor-specific dot1 port-vlan-id
configure lldp port 1:1 advertise vendor-specific dot3 power-via-mdi with-classification
configure lldp port 1:1 advertise vendor-specific avaya-extreme poe-conservation-request
configure lldp port 1:1 advertise vendor-specific avaya-extreme call-server 10.8.*.*
configure lldp port 1:1 advertise vendor-specific avaya-extreme file-server 10.8.*.*
configure lldp port 1:1 advertise vendor-specific avaya-extreme dot1q-framing auto
configure lldp port 1:1 advertise vendor-specific med capabilities
configure lldp port 1:1 advertise vendor-specific med power-via-mdi
now phones are not hanging they are getting registered and working.
but there is disturbance in voice quality/
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,908 Points 5k badge 2x thumb
Please take a look at this article and see if you can prioritize the voice traffic in the network.
https://gtacknowledge.extremenetworks...
I am pointing to this article considering that there are no packet drops in the network.
You might need to check the Voice traffic patch and see if the ports does not drop packets due to high traffic and then you can apply the QOS profile.
Photo of Jason Parker
Jason Parker, Employee
  • 2,918 Points 2k badge 2x thumb
Check out this article to see if these commands work for you.
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-LLDP-commands-are-needed-for-an-Avaya-ph...
Hope this helps
Jason
