iPads drop internet connection while retaining connection to ssid
  • 2
  • Problem
  • Updated 7 months ago
  • Solved
So I have had a problem with iPads losing internet randomly during the day at an Elementary school. I have 2 C35 controllers with 3825 aps running firmware version 10.31.04.0009. It seems that everyday almost a bunch of classrooms have there iPads just start spinning while loading something. The iPads are still connected to the AP with good signal, but will not ping gateway or anything until I either disconnect and reconnect from the wifi or do a hard reset on the iPad. It has been a hard problem to trouble shoot because every time it happens I hear about it afterwards or they are working by the time I get there. This problem has become frustrating to teachers and students because it will happen during the middle of testing sometimes also.
I guess I am just wondering if anyone has had similar  problems and come up with any solutions. I have opened tickets in the past for this. It seems we change something and it works for a couple days so we assume it is working but then I start hearing the same thing again.
Thanks for the help.
Photo of Will
Will
  • 200 Points 100 badge 2x thumb
Posted 11 months ago
  • 2
Photo of John Romero
John Romero
  • 300 Points 250 badge 2x thumb
I am having this same issue, it also happens with Apple phones. I hope someone has a fix for this as I have a bunch of not so happy college students.
Photo of JP
JP
  • 984 Points 500 badge 2x thumb
What firmware are you running ?
(Edited)
John Romero
10.21.03.0010
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
It could be the application itself? We have iPads in our classrooms and, I have seen the iPad connect to the wifi and can get out to Google, but when they open downloaded applications, it will freeze. Or the kids have tons of apps open at one time.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,528 Points 20k badge 2x thumb
What kind of privacy and authentication is set for the WLAN service and is MFP enabled or disabled.
What topology is used.
Photo of Laura
Laura
What does MFP do?
I'd disable it as some clients don't "like" it.
Here a example...
https://community.extremenetworks.com/extreme/topics/some-clients-unable-receive-ip
Photo of Evan Kuckelheim
Evan Kuckelheim
  • 668 Points 500 badge 2x thumb
Please make sure that your ap radio's are configured appropriately for the environment.
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-the-best-radio-settings-for-my-envir...
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,692 Points 5k badge 2x thumb
100% agree with this ... I made these recommended changes across the board a few months and it resolved a lot of glitches in my environment. Remember that "auto" settings with your AP's typically means "out of the box setting" not necessarily "the best setting for most people".
Photo of Volker Kull
Volker Kull
  • 1,740 Points 1k badge 2x thumb
We figured out that IOS does not reauthenticate after leaving sleeping mode. Coming up on a different AP the session is still alive on the past AP.
For this case we limit the session timeout to 30-60min . Than the IOS device is triggered to do a full reauthentication after sleeping mode.
Br
Volker
John Romero
Where you set the Session Timeout?
John Romero
I am not using WPA so MFP doesn't apply. We are MAC authenticating. The Session Timeout seems to be a good option, where is that setting?
Volker Kull
You can configure session timeout in the WLAN service >advanced. So you configure it per service and not for the entire system.
br
Volker
Photo of Will
Will
I am going to try this, we were set at the default of 0. I will post back when I get results.
Photo of Will
Will
So changing the session timeout did not help the problem. Most classrooms still have to either restart their iPads or just shut off and turn on the wifi to get the connection to wake up. It always happens after waking the iPads from sleep.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
Another setting we have seen cause issues with the apples is having UAPSD enabled. When the ipad comes out of sleep mode you need to manually connect back up to the SSID.
