Iproute summary wrong output
  • 2
  • Problem
  • Updated 7 months ago
  • Not a Problem
Hello,
I`d like to know why the command show iproute summary,shows the compressed number of routes are different from the command show iproute.
See this example
Both images are the same switch.
Photo of Julian Eble
Julian Eble
  • 1,394 Points 1k badge 2x thumb
Posted 8 months ago
  • 2
Photo of M.Nees
M.Nees, Embassador
  • 9,168 Points 5k badge 2x thumb
This seems to be an error - i would recommend you to open a GTAC Case to clarify that!
Which EXOS version do you use ?
(Edited)
Julian Eble
16.1.4.2-patch1-10
Photo of M.Nees
M.Nees, Embassador
  • 9,156 Points 5k badge 2x thumb
Try last Version XOS-16.2.4.5-Patch-1-3!
