Is 802.11k recommended in the 10.11.x firmware track?
  • Question
  • Updated 2 years ago
  • Answered
Hello,
I'm curious if 802.11k/Beacon Report/Quiet IE are recommended on C5210 running 10.11.x.  If so, will they impact performance/air usage at all?
I'm curious about the "nearby AP's"  report, which requires 11k in order to view.
Photo of Joshua Puusep
Joshua Puusep
  • 2,264 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Philipp Tittmann
Philipp Tittmann
  • 774 Points 500 badge 2x thumb
Hi Joshua,
you can run 802.1k/Beacon Report/Quit IE without any performance issues on a C5210. I totally recommend the use of 802.11k, because it is needed e.g. for the Nearby AP Report. Through 802.11k your APs will have a better "understanding" of what is going on and what is around.
Regards,
Philipp
Photo of James A
James A, Embassador
  • 6,542 Points 5k badge 2x thumb
I'm running 802.11k on 9.21.12 and 10.11.02. There were some crashing problems with AP3825 but they've all been fixed. Also note that enabling with disconnect all clients from the VNS.
Does anyone know what Beacon Report and Quiet IE actually do? The help page is pretty minimal.
Photo of Rajesh Jeevendran
Rajesh Jeevendran, Employee
  • 354 Points 250 badge 2x thumb
Hi James
Greetings
IE - Information Element could be seen only on Management Frames
Quiet IE
    Dynamic frequency selection was needed to avoid certain military radar technologies.To find the presence of radar or other interference,an AP can use the Quiet element to temporarily shut down the channel to improve the quality of measurements.
Beacon Report
The 802.11k protocol allows APs and clients to dynamically measure the available radio resources.The APs and clients can send neighbor reports, beacon reports and link measurement reports to each other.
This allows the APs and clients to take appropriate connection actions like band-steer,move sticky  client.
The beacon report requests are sent only to 802.11k-compliant clients that advertise Beacon Report Capability in their RRM Enabled Capabilities IE
Client's 11k Beacon Report to AP
BSSID               Channel   RSSI
ff:ff:ff:b6:62:f0     38           92
ff:ff:ff:b6:69:30    38           94
ff:ff:ff:4a:43:d0    46           94
ff:ff:ff:b6:66:30    46           92
Regards
Rajesh J
Photo of Jacob, Praveen
Jacob, Praveen, Employee
  • 1,022 Points 1k badge 2x thumb
Adding to the information already posted above, the 'Nearby AP Report' is a very useful report in understanding roaming options and signal strength of such APs in a WLAN.
(Edited)
