Is ecmp (Equal cost multi Path) supported on BD10K
  • Question
  • Updated 3 years ago
  • Answered
BD10K running 12.6.2.10 code , can it support ECMP
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Stephen Elliott
Stephen Elliott
  • 1,034 Points 1k badge 2x thumb
yep,
enable iproute sharing
configure iproute sharing max-gateways (default 4)
Rod Robertson
Many Thanks , just unsure it was supported with the old code and no configuration notes.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
ECMP is supported on EXOS 12.6 but it is not supported on the 10K.
Rod Robertson
OK the question keep coming re ECMP on a DB10K.
My understanding is that ECMP is configurable on a BD10K ( enable IProute sharing ) running 12.6 code,  but thats it , there are no other configurations that can be made... no tweeks , nothing
