Is it possible to connect 10 G DAC cable to the X460-G2 Front Panel ports for stacking?
  • Question
  • Updated 3 weeks ago
Hi Team,
we have two extreme X-460 core switches, is it possible to connect 2 core switches with 10G DAC cable through the front panel for stacking?
Photo of Niyas
Niyas
  • 354 Points 250 badge 2x thumb
Posted 3 weeks ago
Photo of SH
SH
  • 3,204 Points 3k badge 2x thumb
Hello Niyas,
If you have an 10G switch like X460-G2-48t-10GE4 yes. The alternate stacking ports are 51,52 on the front. You will find such kind of information's for all switches in the EXOS user guide easily.
It will be very helpful if you post the exact switch types. Only in this way we can give you correct information's!
Best regards
Stephan
Photo of Niyas
Niyas
We have Extreme X-460-G2-24P-10GE4 core switch
Photo of SH
SH
You can use front ports 31 and 32 for stacking.
BR
Stephan
Photo of Niyas
Niyas
Thanks for your support...
one more thing,Is it possible to use shared and Sync-E input port for uplink purpose?
Regards
Niyas P
