Is it possible to do a firmware update on a Summit using xmodem/serial port
  • Question
  • Updated 2 years ago
  • Answered
Can't find any description about it..
Photo of Nico Lueck
Nico Lueck
  • 512 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Nico
Yes you can but you have to be in the Bootloader of the switch to use the serial port and it is mainly used as recovery process.
There is a knowledgebase article here https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Use-the-Boot-Rom-Menu-to-Download-a...
Let us know if this helps.
P
(Edited)
Photo of Nico Lueck
Nico Lueck
Hi Paul,
thanks for the quick answer.
But I mean to use the serial connection to download the image.
Regards
Nico
Photo of Alexandr P
Alexandr P, Embassador
  • 12,092 Points 10k badge 2x thumb
Hello, Nico!
No, you can't upgrade through serial.
Also you have to think (if it were possibile (teoretically)) - how long it takes to download image (50MB) with speed 9,6 kbit/sec?
Thank you!
Photo of Nico Lueck
Nico Lueck
That was more a theoretical question, as for SecureStack it is possible
Photo of Drew C.
Drew C., Community Manager
  • 37,742 Points 20k badge 2x thumb
The ExtremeWare products (S200, S300, S400, 48si, etc.) allowed xmodem transfer for code, but the images were much smaller.  On EXOS based hardware, this isn't possible.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,908 Points 5k badge 2x thumb
xmodem took MANY hours when i had to do it.  Especially if you didn't change the console speed.
