Is it possible to install and activate Extreme Management Center using NMS-BASE-250 License...
  • Question
  • Updated 1 year ago
  • Answered
We have recently purchased the  NMS-BASE-250 License for our Network Management. Currently we are using Ridgeline NMS. We are planning to install Netsight 6.3.
Is it possible to install and activate Extreme Management Center using  this NMS-BASE-250 License?
Photo of Thavamani Shanmugam
Thavamani Shanmugam
  • 710 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,470 Points 5k badge 2x thumb
Hello,
Yes, NMS-BASE-250 can be used to install and run Extreme Management Center. Depending on when the entitlement was redeemed you may need to upgrade it through the portal to use it with version 7 or 8, but it will allow you in run Versions 6, 7 or 8.
Thanks
-Ryan
Photo of Schmotter, Ryan
Schmotter, Ryan, Employee
  • 650 Points 500 badge 2x thumb
Yes, the NMS-BASE-250 license allows you to install Extreme Management Center and manage up to 250 devices (managed IP's). I would, however, recommend installing the latest version of EMC, 8.0. There are quite a few improvements over version 6.3.
