Is it possible to re-set the Extreme Management / OneView Wireless Dashboard?
  • Question
  • Updated 2 years ago
  • Answered
I changed one of the report boxes in "Report Designer - Wireless Overview" and it through everything out of whack. Is there a way to re-set the Wireless Overview / Wireless Dashboard report back to default or can someone list the default reports that make up the dashboard so I can put them back in manually.
Photo of Chris Taylor
Chris Taylor
  • 796 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,192 Points 5k badge 2x thumb
Hello,
You should be able to replace the WmDashboard.xml with this file:
https://extremenetworks2com-my.sharepoint.com/personal/ryacobuc_extremenetworks_com/_layouts/15/gues...
Download that file and replace the <Install_Dir>/NetSight/appdata/OneView/Reports/WmDashboard.xml with it.
You may also want to delete the NetSight/Appdata/OneView/MyReports/WmDashboard.xml too.
Thanks
-Ryan
Chris Taylor
Thanks Ryan worked great.  Is there anyway to make the dashboard more "live" ?
What do you mean by more "live"?
Thanks
-Ryan
Chris Taylor
By "more Live" I mean having the information auto refresh at 15 or 30 second intervals
Unfortunately no.
The "Events" pane has an auto refresh option. Also remember that information bye default is collected every 15 minutes, so even if you had an auto refresh every 15-30 seconds the reports wouldn't change until the collector ran it's poll, which is a 15 minute default interval.
Thanks
-Ryan
Also,
You may be able to get a browser plugin that does a timed refresh, so you could refresh every 15 minutes using a plug to get a more live feeling.
I think mozilla has one and there's another conversation around here somewhere, but I can't seem to find it.
Thanks
-Ryan
