Is it recommended to use the management port on C5210 wireless controller
  • Question
  • Updated 2 years ago
  • Answered
We are upgrading from a pair of C4110 wireless controllers to a pair of C5210 controllers. With the C4110 it was recommended to not use the management port to manage the controller but to use 1 of the interfaces. This recommendation goes years back. I was wondering if this is still best practice and applies to the C5210 controllers
Photo of Chris Taylor
Chris Taylor
  • 816 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
Yes it's the same = don't use it.
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,806 Points 5k badge 2x thumb
I can speak from experience. After wasting a lot of time with a lot of people, I have learned this lesson. Don't use it!  :-)
Photo of Patrick Koppen
Patrick Koppen
  • 770 Points 500 badge 2x thumb
You configure a default route with the esa/data-topologies and a default gateway in the admin/mgmt
topology. But you have only one Linux. Yes, it might work.
If you don't how linux with multiple routing tables and routing rules works:
  Dont' use it!
For the others:
root@ewc41:~# ip route show table all | grep 254
default via 192.168.10.254 dev eth0  table mgmt
default via 10.0.40.254 dev csi1  proto zebra
root@ewc41:~# ip rule show
0:      from all lookup local
32765:  from 192.168.10.1 lookup mgmt
32766:  from all lookup main
32767:  from all lookup default
Edit: removed some <pre>
(Edited)
