Is policy based routing supported on Virtual_EXOS?
Antonio_Opromol
Contributor II
Hi, has someone played with policy based routing on Virtual EXOS? Does it works? I've configured it on my virtual exos for NAC captive portal redirect lab, but the virtual exos router don't made the flow redirect of the http traffic as configured...
4 REPLIES 4
Antonio_Opromol
Contributor II
Thanks for the confirm!
Henrique
Thanks for your confirmation Ty!
Ty_Kolff
New Contributor II
I can confirm this is the case. I created some PBR's to test a few weeks ago and they did not function, however the counters showed the ACL's being hit.
Henrique
Hi Antonio, I believe that flow-redirect/PBR use HW resources and won't work in EXOS VM.
You can add a counter in the ACL to confirm. You should see the counter incrementing, but not the next-hop being used.
