Is stacking module support hot plug?
  • Question
  • Updated 4 years ago
  • Answered
Hi Experts,
May I know if stacking modules for Summit450 is supporting hot-plug? Meaning if I can plug it onto SW when the SW is running in live network?
Thanks.
Photo of Leo Gu
Leo Gu
  • 260 Points 250 badge 2x thumb
Posted 4 years ago
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Hello.
I think yes, the stacking modules support hot-plug. In any case, I've attached my VIM2-SS-1 into x480 and everything was good.
Photo of eyeV
eyeV
If I were you I would trust HW Guide.
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
yes.this is documented in hardware guide.
Photo of Drew C.
Drew C., Community Manager
  • 40,846 Points 20k badge 2x thumb
Hello Leo,
As the hardware guide states, the XGM, VIM, and SummitStack modules on the SummitX product line are NOT hot-swappable.  You will need to power off the switch before installation or removal to ensure proper operation and to prevent damage to components.
You mentioned the X450, which does not have a removable stacking module.  You'll find stacking modules for the X460, X480, X650, and the X670V.  The X440 "non-10G" models have built-in stacking ports, as do the earlier SummitX products (X250, X450, X450a/e).
-Drew
