Is the ReachNXT 100-8t compatible with Summit 620 and Summit 670-G2 switches (XOS 21.1.3.7) ?
  • Question
  • Updated 9 months ago
  • Answered
Hi, We would like to use these to connect a one or two low speed ports (10/100Mb) to our 620/670G2 switches running XOS 21.1.3.7. Has anyone run the ReachNXT 100-8t with these units?
I cant find any clear documentation saying yes or no.
Photo of Rowan Sakul
Rowan Sakul
  • 314 Points 250 badge 2x thumb
Posted 9 months ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Rowan,
This should work, although the link between the Summit and the ReachNXT will be 1G (either fiber or copper). Just be sure that LLDP is enabled on the port on the X620 or X670G2 that you connect the ReachNXT to.
Rowan Sakul
Thanks Brandon for replying, will arrange to get one in to test.
Rowan Sakul
FYI, I've had this confirmed as working by GTAC, refer to Case# 01376766
