Is there a way to reset all Purview statistics / data from netsight ?
Gaspard_W
Hello,
I've been using the purview collector / physical appliance to collect test data with the mirror.
I changed the settings of the mirror and want to completely remove all data that was collected before, because it's useless.
Is there way to do it without resetting anything else on netsight ?
6 REPLIES 6
Gaspard_W
Thanks for the replies. I'm going to post a feature request and try your method. I'll keep you updated
Thanks for doubling back Gaspard to let the Community know issue is resolved.
We're really glad you joined the Hub and appreciate your trust in Extreme Networks!
That technique worked, all the data that was older than 24h is now gone, and I only have the new data šŸ™‚
thanks
Mike_Thomas
Although it is not a bullet proof concept, the following can be done to get rid of a lot of the historical data. Loving the days of retention down to 1 day each and then leave on for 48 hours, it should purge a lot of data.
see blow.
