Is there a way to start a scheduled task more often than every hour?
StephanH
Valued Contributor III
Hello,
Is there a way to start a scheduled task more often than every hour in XMC?
If have to start it every five minutes for example.
If necessary to edit some hidden files, that is not a problem for me 😉.
Best regards
Stephan
0ad3585017e143e29272420d0c623731_RackMultipart20181028-118092-1bkz3nb-image_inline.png
Regards Stephan
5 REPLIES 5
StephanH
Hello Matthias,
thenk you for your tips. I already know both and I have already tried to solve my problem with it. I also found the table where the time is stored (ns_qrtz_cron_triggers).
However, there are several dependencies on other tables regarding start and end times as well as the value "next run" from the Scheduled Task. Therefore, it is difficult to see whether manual changes are needed and do not break anything.
Thus, the idea of ​​Ron is easier implement.
There is already a FR 0170550 with the desire to change the behavior via the GUI.
Best regards
Stephan
Regards Stephan
M_Nees
Contributor III
Hi Stephan,
do you know this:
5bd88901d742448bb0df4e3d71963ea1_RackMultipart20181101-126809-10estn4-scheduler_inline.png
M_Nees
Contributor III
Hi Stephan,
all tasks are saved in XMCs local mysql database.
With necessary SQL knowledge you can multiply the needed tasks as you need.
Unfortunately i never try.
Regards
StephanH
Hey Ron,
that's a good idea. It's a nasty workaround but much better than nothing and it works.
Best regards
Stephan
Regards Stephan
