Is there any other infromation other than "Port 1 link down - Local fault" available to troublshoot intermittant issue?
  • Question
  • Updated 10 months ago
  • Answered
Switch 1 -
  • X670G2-48x-4q      Created by ExtremeXOS version 15.6.4.2
  • Port      Temp    TxPower  RxPower  TxBiasCurrent  Voltage-Aux1/ Voltage-Aux2
           (Celsius)   (dBm)    (dBm)     (mA)         Vcc (Volts)       (Volts)
    1         28.96    -2.06    -8.27     30.30         3.24          N/A
          N/A - parameter not applicable to transceiver connected to the port
          *   - value is out of normal range
  • 01/30/2018 10:54:55.12 <Info:vlan.msgs.portLinkStateUp> Port 1 link UP at speed 10 Gbps and full-duplex
    01/30/2018 10:54:53.64 <Info:vlan.msgs.portLinkStateDown> Port 1 link down - Local fault
    01/30/2018 10:54:52.59 <Info:vlan.msgs.portLinkStateUp> Port 1 link UP at speed 10 Gbps and full-duplex
    01/30/2018 10:54:50.77 <Info:vlan.msgs.portLinkStateDown> Port 1 link down - Local fault
Switch 2-
  • X440-24t-10G   Created by ExtremeXOS version 15.7.1.4
    26        35.84    -1.56    -5.57     36.75         3.19          N/A
  • 01/30/2018 10:54:53.93 <Info:vlan.msgs.portLinkStateUp> Port 26 link UP at speed 10 Gbps and full-duplex
    01/30/2018 10:54:53.84 <Info:vlan.msgs.portLinkStateDown> Port 26 link down - remote fault
    01/30/2018 10:54:47.49 <Info:vlan.msgs.portLinkStateUp> Port 26 link UP at speed 10 Gbps and full-duplex
    01/30/2018 10:54:47.42 <Info:vlan.msgs.portLinkStateDown> Port 26 link down - remote fault
Is there any other information which I can help use to troubleshoot this issue?   It started 1/26/2018 about 6 hours after  a power event (01/20/2018 08:07:49.55 <Warn:EPM.UnexpctRebootDtect> Booting after System Failure.).
I have already swapped optics and will be heading 2 hours to the site to swap ports.
Any additional insight would REALLY be appreciated.
Photo of Joe Sheldon.
Joe Sheldon.
  • 144 Points 100 badge 2x thumb
Posted 10 months ago
Photo of EtherMAN
EtherMAN, Embassador
  • 7,370 Points 5k badge 2x thumb
I would question why you have almost a 3 db difference in light levels on such a short run... Was that extra loss there before the port flaps?  If not then you may have a bend in a splice case somewhere or a patch problem... maybe it not seated in frame on back side ... As a rule we try to keep under 2 db difference in fiber loss on ten gig links.  Longer links we are more flexible but a short link the fibers should have very close to the same loss...
Joe Sheldon.
The link is approx 4 miles and the customer has moved our gear. They are using a multi mode patch cable on the single mode link. While this is wrong and being corrected today, the link was working over it until recently.
Photo of Bin
Bin, Employee
  • 5,374 Points 5k badge 2x thumb
Hi Joe,
Please check these articles
1.
link down - Local Fault
2.
EXOS Local Fault Issue with Direct-Attach Cables
If none of these articles could not help you, I suggest you to open case to our GTAC
https://gtacknowledge.extremenetworks.com/articles/How_To/Create-a-Case-via-New-Portal
Best regards,
