Simulating an Openflow controller
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
is there any simulator for using Openflow controller instead of Open-Flow Switches ..if so , Pls guide me
Photo of Arun Samuel
Arun Samuel
  • 70 Points
Posted 3 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,040 Points 5k badge 2x thumb
Mininet is what everyone uses for testing with openflow nodes.
Tutorial:
https://github.com/mininet/openflow-tutorial/wiki
Video:
https://www.youtube.com/watch?v=jmlgXaocwiE
(Edited)
Photo of Deadpool
Deadpool
  • 380 Points 250 badge 2x thumb
You could also use the following:
 HPE-VAN SDN Controller with Flowmaker Deluxe
Floodlight
Opendaylight
Ryu
ONOS
No idea if they work with any Extreme switches, but they work fine with PicOS and Mininet.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,526 Points 10k badge 2x thumb
floodlight is working, but a bit limited (at least was when I used it). Opendaylight will work too. Never tested the others.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,720 Points 10k badge 2x thumb
To test OpenFlow support of EXOS switches (with openflow.xmod and appropriate license installed) without installing a controller, one can use the "dpctl" utility from the openflow Git repository git://yuba.stanford.edu/openflow .
Hm, dpctl cannot be used with EXOS based switches, because EXOS does not correctly configure a "passive" controller. The "passive" controller seems to listen on localhost only:
Controller       : Secondary
Status : INACTIVE
Datapath ID : 00000800273d25b3
VR : VR-Mgmt
Mode : out-of-band Passive
Target : ptcp:127.0.0.1:6633
Uptime(secs) : 0
As a result dpctl cannot connect to the switch:
$ ./dpctl show tcp:192.168.42.3:6633
dpctl: talking to tcp:192.168.42.3:6633: Connection refused
$ telnet 192.168.42.3
Trying 192.168.42.3...
telnet: Unable to connect to remote host: Connection refused
$ ping -c1 192.168.42.3
PING 192.168.42.3 (192.168.42.3) 56(84) bytes of data.
64 bytes from 192.168.42.3: icmp_seq=1 ttl=64 time=1.13 ms
--- 192.168.42.3 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 1.135/1.135/1.135/0.000 ms
$ ssh admin@192.168.42.3 "show openflow"
admin@192.168.42.3's password:
OpenFlow: Enabled
Versions: OpenFlow10, OpenFlow13
Mode: Standard
FDB: On
Access-list width: Single
---< further output omitted >---
Just tested with EXOS 21.1.1.4, which includes OpenFlow in the base image.
