is there any way to export the list of APs with radio channel and power settings from the controller?
Ron_Fabrici
I need a way to quickly and regularly document the settings on ~700 APs, is there any way to export the list of APs with radio channel and power settings from the controller?
4 REPLIES 4
Zdeněk_Pala
You can use snmp to get this information. Netsight does have bflexviews with such info I believe...
Regards Zdeněk Pala
Ron_Fabrici
the .xml file works perfectly, thanks so much!
Jeremy_Gibbs
Contributor
Also, if you can SSH to the controller, type in shell and enter this command (you can also just type in show ap_inventory, but this will allow you to redirect output to a file.
/var/controller/bin/chantrysh -c "show ap_inventory" > ap-list.txt
Jeremy_Gibbs
Contributor
Active APs from reports tab. Export as an xml and use excel to open.
