iSCSI issues
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Feb 22 2012 9:51AM
Hello,
I'm trying to setup iSCSI over an X670, between a Windows host and an Equallogic PS4100 array
The Equallogic box is connected on a single gig port via a 1000T SFP, the Windows box has an Intel X520 10gig card installed, using a 3m twinax cable. Both of those have jumbo frames enabled.
On the x670 I have "enable jumbo-frame ports all" set. I've created a new VLAN and untagged it on the ports for both units.
From the server I can ping the Equallogic unit, "ping -l 8000 ip.ad.re.ss" works ok. When mounting an iSCSI volume and running Wireshark I can see lots of 'TCP Dup ACK', 'TCP Window Update' and 'TCP Retransmission' events, after a few seconds the drive hangs.
* Slot-1 LL_10G_STACK1.87 # show port 1:20,1:34 information
Port Flags Link ELSM Link Num Num Num Jumbo QOS Load
State /OAM UPS STP VLAN Proto Size profile Master
esxstg1_> Emj-----e--fMB---b active - / - 6 0 1 1 9216 none
eqlarr1_> Emj-----e--fMB---b active - / - 1 0 1 1 9216 none
Any ideas? If I connect the Windows box up via a gig cable direct to the array the performance is fantastic.
Thanks,
(from nat_morris)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Feb 23 2012 12:55AM
whats the port state of these two ports (speed, duplex)?
Did you already checked the ports for errors?
Best regards
Falk
(from Falk_Fischer)
Create Date: Feb 23 2012 5:22AM
The ports duplex is ok, the Equallogic box is linked at 1000 full and the SFP+ cables are linked at 10G.
Previously the X670s were configured in a SummitStack with 2 SFP+ twinax cables between them (on ports 47+48), I've just wiped their configs and am giving it a go on a single standalone box.
(from nat_morris)
Create Date: Feb 23 2012 6:28AM
Just wiped the box, so it now only has 5 ports in use.
33 - Equallogic Controller A port 1, 1000T SFP
34 - Equallogic Controller A port 2, 1000T SFP
35 - Equallogic Controller B port 1, 1000T SFP
36 - Equallogic Controller B port 2, 1000T SFP
41 - Dell Server, Twinax SFP+
On Wireshark running on the server we see lots of TCP out-of-order, retransmission and window update messages.
Strange thing is, if I hook all 4 gigE ports from the Equallogic up to a Netgear gig switch, then a single gig cable from that to the X670 everything works well.
Any ideas? thanks!!
(from nat_morris)
Create Date: Feb 24 2012 3:42AM
These are the combinations that work and those that don't:
(from nat_morris)
Create Date: Mar 10 2012 10:57AM
What xos version are you using ?
And it might be that you see those out of sequence packets due to tcp /ip offloading on the servers nic card.
And what are the lacp /lag settings on the box ?
(from Erik_Bais)
