EXOS traceroute displaying !O flag on each response
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
When executing a trace route to a LAN address from a switch Core Black Diamonf 8010, it sends me the following  output
1  10.7.136.146                                 4 ms !O     7 ms !O     1 ms !O
2  10.7.136.146                                 5 ms !O     1 ms !O     5 ms !O
3                                               *
3  10.7.136.146                                             3 ms !O     *
4  10.7.136.146                                 4 ms !O     *           9 ms !O
5                                               *
My question is what does the !O mean, It seams like I am having a route flapping, rigth?
Thanks  in advanced for your answr
Photo of Luis Rivera
Luis Rivera
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hi Luis,
What version of code are you running? The command reference guide should have something about this flag.
Luis Rivera
ExtremeXOS version 15.7.2.9 v1572b9 by release-manager
Do the flags show up after the command is finished running?
Luis Rivera
Yes It does, the flags are shown for all the 30 hops until finished
Luis Rivera
Yes they do, the flags are shown for all the 30 hops until finished
Luis Rivera
ok, thaks, for your help
regards
Photo of Paul Thornton
Paul Thornton
  • 1,374 Points 1k badge 2x thumb
Hi
I've never seen the '!O' output on a line - and it isn't in Cisco's list of letters that traceroute responds with sometimes.
Normally, when traceroute says "!something" it means that an ICMP message other than echo reply came back, and the letter determines what that ICMP message was.
But I can't help you with the !O ... perhaps someone else knows that magic code.
Paul.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,552 Points 10k badge 2x thumb
this flag should have been added to the list, I'm surprised this is not the case. This is the catch all entry in the code. It means "other", ie the result was one of the missing types (types not defined in the code).
