Issue of random recognition of SFP+ coded Extreme on the x620-10x
  • 2
  • Problem
  • Updated 2 years ago
  • Solved
Two versions of XOS has been tested: 21.1.1.4 patch1-2 and 21.1.1.4 patch 1-5
The Same SFP connected on differents ports displays different errors messages. The interfaces are sometime functional sometime not functional, they are flapping.
The similar SFP modules are functioning on our Production environment without issue.
Photo of AIT Support
AIT Support
  • 150 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,594 Points 10k badge 2x thumb
Hi AIT Support,
I have made this conversation public, as it looks like there is not any personal information present. This way, the entire community can help out and learn from this conversation.
Can you post the error messages you have been seeing? Also, please let us know the SFP models you are using.
-Brandon
AIT Support
07/05/2016 09:19:44.15 <Erro:HAL.Port.ReadOpticDDMIDataFail> : Reading of DDMI data failed on the optical module in port 7.
07/05/2016 09:19:44.15 <Erro:HAL.Port.Error> : summitCardPortGetTransceiverInfoSfp: Unable to read DDMI info from Transceiver for port 1:7
07/05/2016 09:19:44.15 <Warn:HAL.Port.Warning> : Optics module in port 7 is not Ddmi capable
07/05/2016 09:18:09.94 <Erro:HAL.Port.ReadOpticDDMIDataFail> : Reading of DDMI data failed on the optical module in port 7.
07/05/2016 09:18:09.94 <Erro:HAL.Port.Error> : summitCardPortGetTransceiverInfoSfp: Unable to read DDMI info from Transceiver for port 1:7
07/05/2016 09:18:09.94 <Warn:HAL.Port.Warning> : Optics module in port 7 is not Ddmi capable
07/05/2016 09:18:06.99 <Info:vlan.dbg.info> : Media SF+_UNKNOWN is inserted into Port 7
07/05/2016 09:18:04.98 <Info:vlan.dbg.info> : Media SF+_UNKNOWN is removed from Port 9
07/05/2016 09:17:42.76 <Erro:HAL.Port.ReadOpticDDMIDataFail> : Reading of DDMI data failed on the optical module in port 9.
07/05/2016 09:17:42.76 <Erro:HAL.Port.Error> : summitCardPortGetTransceiverInfoSfp: Unable to read DDMI info from Transceiver for port 1:9
07/05/2016 09:17:42.76 <Warn:HAL.Port.Warning> : Optics module in port 9 is not Ddmi capable
07/05/2016 09:17:30.15 <Info:vlan.dbg.info> : Media SF+_UNKNOWN is inserted into Port 9
Port :  9
    Media Type            : SF+_UNKNOWN (Unsupported)
    Vendor Name           : F3EOTI
    Part Number           :8_?6w2
    Serial Number         : AMW
    Wavelength            : 850 nm
    Temp (Celsius)            :  127.28     Status               :  High Alarm
          Low Warn Threshold  : -5.00       High Warn Threshold  :  127.00
          Low Alarm Threshold :  127.00     High Alarm Threshold :  127.00
    Voltage AUX-1/Vcc (Volts) :  3.33       Status               :  High Alarm
          Low Warn Threshold  :  3.05       High Warn Threshold  :  3.50
          Low Alarm Threshold :  3.00       High Alarm Threshold :  1.61
    Tx Power (dBm)            : -1.96       Status               :  Low Warning
          Low Warn Threshold  :  5.15       High Warn Threshold  :  0.00
          Low Alarm Threshold : -9.39       High Alarm Threshold :  1.03
    Rx Power (dBm)            : -22.01      Status               :  Low Alarm
          Low Warn Threshold  : -12.10      High Warn Threshold  : -0.00
          Low Alarm Threshold : -14.55      High Alarm Threshold :  1.03
    Tx Bias Current (mA):        65.15      Status               :  High Alarm
          Low Warn Threshold  :  1.68       High Warn Threshold  :  65.09
          Low Alarm Threshold :  1.00       High Alarm Threshold :  49.73
Port :  7
    Vendor Name           : FXOPOIX
    Part Number           :  N/A
    Serial Number         :  N/A
    Wavelength            : N/A
    Temp (Celsius)            : --          Status               :  N/A
          Low Warn Threshold  :  N/A        High Warn Threshold  :  N/A
          Low Alarm Threshold :  N/A        High Alarm Threshold :  N/A
    Tx Power (dBm)            :  N/A        Status               :  N/A
    Rx Power (dBm)            :  N/A        Status               :   N/A
    Tx Bias Current (mA):        N/A        Status               :   N/A
AIT Support
Brandon
It is an non native module but coded Extreme.
Eva
AIT Support
Hi Brandon
Any help ?
regards
eva
Are these Extreme optics? If so, what is the model number?
From the output you provided, it looks like the switch is having trouble reading information from the optic.
AIT Support
Hello Brandon,
The model is Flexoptix" all models => 1G T, SX, LX, EX et 10G SR, LR, ER.
Thanks  you for your support.
Regards,
Lionel MOUZONG
Since these are not Extreme optics, they are not supported in EXOS switches. While they may work, our SQA team has not tested and verified that they will work. Additionally, we cannot bring any interoperability issues with third party optics to our engineering team for their analysis.
I would suggest testing with Extreme optics, to see if the same behavior is present.
Photo of Alexandr P
Alexandr P, Embassador
  • 12,766 Points 10k badge 2x thumb
Hello, all!
Have the same problem, but only with OpticQ transceivers for 1 fiber.
Other non-original optic show ddmi fine.
Trying X620-10x and -16x.
In X460 and X670 all work fine.
The impression like problem with EXOS 21 version.
X620-16x.6 # debug hal show optic-info port 1
Port                       1
SFP or SFP+:               SFP
Signal:                    not present
TX Fault:                  no
SFP/SFP+ Vendor:           ?E7
SFP/SFP+ Part Number:      ?F_'0
SFP/SFP+ Serial Number:    SG33908
SFP/SFP+ Manufacture Date: 3
SFP/SFP+ Type:             SFP/SFP+
Connector:                 LC
GE Compliance:             UNKNOWN (0x0)
Wavelength:                1135
Is there some update for now?
Thank you!
Photo of Ed Kott
Ed Kott
  • 70 Points
I've just noticed this too in my X620-16x.  VELOSO SFP+ transceivers give the same type of DDMI errors and Extreme Networks branded transceivers manufactured by OPNEXT, INC., FIBERXON INC. and FINISAR CORP seem to be fine.  It's like the switch is looking for an Extreme serial number in order for the DDMI to work properly.
Photo of Alexandr P
Hello!
As I understand this issue only in X620 switches.
Tring with X460G2-24t-10G.
EXOS 15.6.3.1 patch1-9; 16.1.3.6 patch1-9; 21.1.1.4 patch1-5
All this versions, and 21 version too, show correct ddmi:
X460G2-24t-10G4.3 # debug hal show optic-info port 30
Port                       30
SFP or SFP+:               SFP+
Signal:                    not present
TX Fault:                  no
SFP/SFP+ Vendor:           OEM
SFP/SFP+ Part Number:      SFP+ BIDI-20
SFP/SFP+ Serial Number:    SG3P390008
SFP/SFP+ Manufacture Date: 160326
Any ideas about why this issue only with X620 switches?
Thank you!
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,676 Points 10k badge 2x thumb
I have asked internally about it. I was doubtful this was software related as I never heard of specific change for optic support. Thanks for testing on x460G2.
Photo of Alexandr P
  • 12,712 Points 10k badge 2x thumb
Thank you!
Photo of Alexandr P
Hello, colleagues!
Is there any update information about this issue?
Thank you!
There's no real explanation to it, and that just illustrates what is the difference between a generic transceiver and an Extreme one: validation. Nothing has change, but the x620 is - obviously - a different switch, with different interface, different traces length... so maybe this can trigger a problem more often with some 3rd party transceivers?
Photo of Alexandr P
Hello, all!
For now more often appear issue with DDMI SFP+ of non-original optics.
As with X620-10x, so with X620-16x.
What do you think - is it makes sense to open the case in GTAC?
Or because this is non-original optics there is no any reason?
Thank you!
