Issue vlan 08g series
  • Question
  • Updated 2 years ago
  • Answered
I have problemas with 800 series. I change the port from the default vlan, the switch accept config but not register ANY mac on this new fid.  I update de firmware but sitll the same problem... Any idea??
Photo of Luis Mendes
Luis Mendes
  • 1,690 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,732 Points 2k badge 2x thumb
Can you share the configuration?  Does the port show link?  Does the other device show link?
Luis Mendes
config vlan default delete 1-28
config vlan default advertisement enable
create vlan MGMT tag 2
config vlan MGMT add tagged 24-28
config vlan MGMT add untagged 21,23 advertisement disable
create vlan ADSL tag 40
config vlan ADSL add tagged 22-27 advertisement disable
create vlan WIFI_ADM tag 55
config vlan WIFI_ADM add tagged 25-28
config vlan WIFI_ADM add untagged 17 advertisement disable
create vlan MATRIZ tag 97
config vlan MATRIZ add tagged 23-28
config vlan MATRIZ add untagged 1-22 advertisement disable
create vlan CRISTOVAO tag 199
config vlan CRISTOVAO add tagged 21,23-28 advertisement disable
disable qinq
disable gvrp
disable vlan_trunk
config port_vlan 1-15,18-22 gvrp_state enable ingress_checking enable acceptable_frame admit_all pvid 97
config port_vlan 16 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 55
config port_vlan 17 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 97
config port_vlan 23 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 2
config port_vlan 24-28 gvrp_state disable ingress_checking enable acceptable_frame admit_all pvid 1
I Configured with CHROME and IE. Now i see the port 17 on TWO VLANS on configuration (WIFI_ADM) and MATRIZ.
The configuration when executed via browser dont SET the gvrp on config.. but show the correct config via browser.. when i execute via CLI .. works..
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Have you also set the VLAN in the GVRP settings - the 800series is a little "weird" when it comes to the VLAN settings for a unttagged port.....
from point# 9
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Assign-a-Port-To-a-Vlan-on-the-800-...
