Issue with loopback interface with remote mirroring
  • Problem
  • Updated 2 years ago
  • Not a Problem
  • (Edited)
Hi all.
I configured remote mirroring according to "EXOS_User_Guide_16_1".
Remote mirror seems to work but i got BPDU error on intereface assigned as loopback for mirroring.
mirroring config:
  create mirror "voip-span"
  configure mirror voip-span to port-list 51,52 loopback-port 48 remote-tag 1000
  configure mirror voip-span add vlan "PHONE" ingress
  enable mirror voip-span
error message:
  02/25/2016 11:21:24.02 <Erro:STP.InBPDU.Drop> : Port=48: Recv own loop back packet from same port
  02/25/2016 11:21:26.01 <Erro:STP.InBPDU.Drop> : Port=48: Recv own loop back packet from same port
  02/25/2016 11:21:28.02 <Erro:STP.InBPDU.Drop> : Port=48: Recv own loop back packet from same port
i got this on every switch i use as mirror source.
switch:
System Type:      X460G2-48p-10G4
Image:                ExtremeXOS version 16.1.1.4 by release-manager
During that error i got disruption with connectivity - every few pings are lost.
How can i resolve that ? Any ideas ?
Photo of Marek T
Marek T
  • 100 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Marek,
Is there any configuration (Vlan, STP, etc) in the loopback port 48?
Photo of Marek T
Marek T
Hello.
No nothing is configured. I believe STP is added by mirroring configuration.
 # show vlan ports 48
Error: The specified ports are not members of any VLANs.
# show "s0" ports 48
Port   Mode   State      Cost  Flags     Priority Port ID Designated Bridge
48     802.1D FORWARDING 20000 eDap-w---- 128      8030    80:00:00:04:96:99:83:e8
Total Ports: 1
 ------------------------- Flags: ----------------------------
1:                e=Enable, d=Disable
2: (Port role)    R=Root, D=Designated, A=Alternate, B=Backup, M=Master
3: (Config type)  b=broadcast, p=point-to-point, e=edge, a=auto
4: (Oper. type)   b=broadcast, p=point-to-point, e=edge
5:                p=proposing, a=agree
6: (partner mode) d = 802.1d, w = 802.1w, m = mstp
7:                i = edgeport inconsistency
8:                S = edgeport safe guard active
                  s = edgeport safe guard configured but inactive
8:                G = edgeport safe guard bpdu restrict active in 802.1w and mstp
                  g = edgeport safe guard bpdu restrict active in 802.1d
9:                B = Boundary, I = Internal
10:               r = restricted role, t = active role
that is avlan that created itself when remote mirror was added
 # show vlan "internalMirrorLoopback_0"
VMAN Interface for mirroring with name internalMirrorLoopback_0 created by user
    Admin State:         Enabled     Tagging:Untagged (Internal tag 4092)
    Description:         None
    Virtual router:      VR-Default
    IPv4 Forwarding:     Disabled
    IPv4 MC Forwarding:  Disabled
    IPv6 Forwarding:     Disabled
    IPv6 MC Forwarding:  Disabled
    IPv6:                None
    STPD:                s0(Enabled,Auto-bind)
    Protocol:            Match all unfiltered protocols
    Loopback:            Disabled
    NetLogin:            Disabled
    OpenFlow:            Disabled
    TRILL:               Disabled
    QosProfile:          None configured
    Egress Rate Limit Designated Port: None configured
    Flood Rate Limit QosProfile:       None configured
    Ports:   3.           (Number of active ports=3)
       Untag:    *48L,    *51,    *52
        Flags:    (*) Active, (!) Disabled, (g) Load Sharing port
                  (b) Port blocked on the vlan, (m) Mac-Based port
                  (a) Egress traffic allowed for NetLogin
                  (u) Egress traffic unallowed for NetLogin
                  (t) Translate VLAN tag for Private-VLAN
                  (s) Private-VLAN System Port, (L) Loopback port
                  (x) VMAN Tag Translated port
                  (G) Multi-switch LAG Group port
                  (H) Dynamically added by MVRP
                  (D) TRILL Designated, (A) TRILL Appointed Forwarder
                  (I) Dynamically added by IDM
                  (U) Dynamically added uplink port
                  (V) Dynamically added by VM Tracking
Port 51,52 are uplink port to other switches.
Marek
Photo of Henrique
Henrique, Employee
Hi Marek, are you using STP for remote-mirroring to have redundancy as described in the EXOS UserGuide? Can you please share the topology?
Try to remove the loopback port from S0 STPD using the command below and please share the results:
configure s0 delete vlan internalMirrorLoopback_0 ports 48
Photo of Marek T
Marek T
Hi.
Topology in short looks like this with "access switch loop to core" multiplicated on 3 different floors:
When I remove loopback from stp errors stop showing up.
But now i have other issue  - when LAG or even single link in lag between access switches is connected i got 50-60% cpu usage on all switches in network ! even on those on server side - so it looks like some storm or something. in TOP I just see bcmRX to use as mush as 40-50% of cpu.
And it is like this only on one floor.
I`m looking into STP but cannot find an issue. I think i`ll need to first figure out what is the issue with that connection and then take care of that mirroring.
Photo of Henrique
Henrique, Employee
Hi Marek,
That behavior (CPU utilization / bcmRX) indicates looping and it needs to be fixed prior to the remote-mirroring configuration.
Based on this topology, if all those devices are EXOS platform I would recommend you to enable EAPS instead of STP.
How many vlans have you extended among those 6 devices? Also, can you please confirm if all those units are EXOS platforms?
Photo of Marek T
Marek T
Yes all are exos devices.
I`ll go through all STP and vlan config once again on all switches and than we`ll see if problem with mirroring is still occuring.
Thanks Henrique.
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
Hi Marek, were you able to get this resolved?
