Issues with IPv6 on EXOS 22.2
  • Question
  • Updated 1 year ago
  • Answered
Hi all,
I experienced problems with IPv6, local services and 22.2.1.5 firmware. When I upgraded to this version, I could no longer access the switch through ssh or telnet ports using IPv6 address, but only with IPv4 address.
Nmap pointed to IPv6 switch address shows all ports as closed, and to IPv4 address shows ssh and telnet ports open.
Anyone with same issue? I was able to reproduce the same behavior with EXOS-VM_v22.2.1.5-disk1.qcow2 and GNS3.
Best regards,
Ariel
Note: This conversation was created from a reply on: Stay away from EXOS 22.2.1.5.
Photo of alm
alm
  • 60 Points
Posted 1 year ago
Photo of Drew C.
Drew C., Community Manager
  • 37,336 Points 20k badge 2x thumb
Hello Alm,
If you're still experiencing this problem, please open a case with GTAC so it can be reported to engineering for a resolution.
