Issues with Server ALB (Adaptive Load Balancing)
Ian_Broadway
New Contributor III
Hi There,
I'm trying to get more information about ALB. We've got some servers using it and we're seeing odd behaviour.
The scenario is, two edge switches in an eaps ring with two cores, switches on the edge are 450-G2's, code on the edge is 16.1.3.6 and the cores are BD8810s and the code is the same.
There is an EAPS ring with the master node at the edge, where the master node is blocking a leg to one of the cores, therefore meaning the two edge switches can talk between eachother without eaps interfering.
The issue is, the hosts on the edge switches can't talk correctly to the rest of the network when the ring is complete, i have to physically disable a leg to one of the cores to get it to work correctly. it doesn't matter which leg to either core.
I have read that ALB doesnt require any special switch configuration and that it should support two nics from the same server, one in each of the switches to allow load balancing and switch resilience.
hope that makes sense.
anyone had any experience with this? would it be better to go the LACP route?
we would use MLAG to pair the switches in essence and configure LACP on the servers.
Ian
1 REPLY 1
Erik_Auerswald
Contributor II
Hi Ian,
what is ALB and how does it work? Does it use multicast, which might interact with IGMP snooping on the switches? Do you have any links to documentation?
Thanks,
Erik
