Issues with VOSS 7.0 in GNS3
  • 2
  • Question
  • Updated 3 weeks ago
  • Answered
Does anyone have a set of release notes for the virtual VOSS 7.0 image on Github that details exactly what features are / are not supported?
The good news is that I have been able to configure a pair of switches, in GNS3, to form a virtual IST and can ping between the switches using ip shortcuts or L2VSN.
The bad news is that I can not ping through the cluster across a L2VSN.  Both switches are configured for VLAN 20, I-SID 1602000 with 172.16.20.0/24 IPs and can ping each other no problem.   However, virtual PCs on VLAN 20 can ping the local interface but neither the far side switch nor VPC.   I enabled ip shortcuts and redistributed (and applied) direct interfaces to cover my bases.   Sniffing the IST shows the ARP request going across but no response.
This version of code does not appear to support trace levels, l2/l3 iotables, or cfm cmac.
Has anyone gotten this working?
Photo of Joseph Wood
Joseph Wood
  • 102 Points 100 badge 2x thumb
Posted 3 weeks ago
  • 2
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,562 Points 10k badge 2x thumb
There's no dataplane at the moment for mac-in-mac with the VM. So you cannot transit data.
Photo of Antonio Opromolla
Antonio Opromolla
  • 2,126 Points 2k badge 2x thumb
HI, can be great if someone load the gns3 project of these tests with VOSS in GitHub in manner to exchange suggestions between users.
Joseph Wood
Thanks for the confirmation.   I had heard that before but was surprised that I even got a virtual IST working so was hoping it was incorrect.
