isw Power budget
isw Power budget
Jake_Koch
Hello Extreme Community,
I am trying to find out how much power the:
-ISW 4GBP,2GBT,2-SFP
-ISW 8GBP,4-SFP
(part no.16803 and 16804)
Switches require to run without any PoE devices and what is the max power consumption total with all PoE+ ports outputting 30watts.
Will the ISW 4GBP,2GBT,2-SFP be able to output 30w PoE+ on all 4 ports with a 240w PSU ?
thanks
Jake
6 REPLIES 6
Sushruth_Sathya
Hi Jake,
Yes, you are right. Without PD loading, it is 15W. With full PD loading, it will be 15+240W = 255W.
Jake_Koch
bump to get clarification on what 'PD loading' means in the Data Sheet.
Jake_Koch
Thanks Sushruth,
I have checked the data sheet. I am not clear what PD Loading means. I was hoping to find a total power usage of the switch when it is turned on running with all ports connected without PoE... is that what 'without PD loading' means ? (the switch only takes 15w to operate with all ports linked up and running at 1gbps ?)
jake
Sushruth_Sathya
Hi Jake,
The PoE budget according to the ISW data sheet is -
• POE Budget 16801 and 16803 – 120 watts
• POE Budget 16802 and 16804 – 240 watts
And without PD loading, the consumption is 15 W.
