Jumbo Frame & IP MTU
  • Question
  • Updated 3 years ago
  • Answered
If I'm using "configure ip-mtu vlan" for specifying MTU size for a specific VLAN, should I use "enable jumbo-frame ports" for each port associated to that VLAN?
What is the relation with "configure jumbo-frame-size" if there are more than one tagged VLAN with different MTU on "configure ip-mtu vlan" with same associated ports?
Best regards,
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,454 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Prabhakar Rao Murula Venkat
Prabhakar Rao Murula Venkat, Employee
  • 160 Points 100 badge 2x thumb
As per our implementation,"config ip-mtu size vlan" doesn't impact ipv4 jumbo frame data path traffic provided whether  jumbo frame is enabled on ingress and egress L3 vlan ports using cmd "enable jumbo-frame ports".So,  for fast path routing of ipv4 jumbo frame we need to enable jumbo-frame ports.
I believe there is no relation of "configure jumbo-frame size"  with different L3 MTU for more than one tagged VLAN as for as  ipv4 data path traffic is concerned .
L3 MTU size impact only l3 slow path traffic and some routing protocols.
(Edited)
Photo of OscarK
OscarK, ESE
  • 7,702 Points 5k badge 2x thumb
enable jumbo-frame ports <ports> is for L2 switching of packets.
The IP-MTU setting on vlans is for L3 routing to route jumbo frames.
You cannot increase the ip-mtu without also enabling jumbo frames on the involved ports.
(Edited)
Mrxlazuardin
HI Oscar,
Can you give me some example of mixed tagged and untagged VLAN configuration of a port with different MTU for each VLAN (some with normal 1500 MTU)?
Best regards,
Photo of OscarK
OscarK, ESE
Just enable jumbo-frames on the ports, keep the default jumbo-frame size.
Then for each vlan you need to route bigger packets set the ip-mtu for that vlan to the value needed. Add the vlans to the ports.
