Kernel Card Warning
  • Problem
  • Updated 4 years ago
Dear All,
recently we found that almost for one week long we are getting the following messages in logs for the stack of two X670V-48x for every 3 seconds:
07/28/2014 19:17:21.55 <Warn:Kern.Card.Warning> Slot-2: i2c-1: sylvester_plugincard_temp:1879 I/O failed, addr 0x0048 rd/wr 1 cmd 0 proto 3, rc 14507/28/2014 19:17:18.68 <Warn:Kern.Card.Warning> Slot-2: i2c-1: summitxlsPsuGetUcReg:7360 I/O failed, addr 0x003e rd/wr 1 cmd 3 proto 3, rc 145
07/28/2014 19:17:18.68 <Warn:Kern.Card.Warning> Slot-2: i2c-1: summitxlsPsuGetUcReg:7360 I/O failed, addr 0x003e rd/wr 1 cmd 2 proto 3, rc 145
07/28/2014 19:17:18.68 <Warn:Kern.Card.Warning> Slot-2: i2c-1: summitxlsPsuGetUcReg:7360 I/O failed, addr 0x003e rd/wr 1 cmd 1 proto 3, rc 145
07/28/2014 19:17:18.67 <Warn:Kern.Card.Warning> Slot-2: i2c-1: summitxlsPsuGetUcReg:7360 I/O failed, addr 0x003e rd/wr 1 cmd 3 proto 3, rc 145
07/28/2014 19:17:18.67 <Warn:Kern.Card.Warning> Slot-2: i2c-1: summitxlsPsuGetUcReg:7360 I/O failed, addr 0x003e rd/wr 1 cmd 2 proto 3, rc 145
07/28/2014 19:17:18.67 <Warn:Kern.Card.Warning> Slot-2: i2c-1: summitxlsPsuGetUcReg:7360 I/O failed, addr 0x003e rd/wr 1 cmd 1 proto 3, rc 145
Slot:             Slot-1 *                     Slot-2                  ------------------------     ------------------------
Current State:    MASTER                       BACKUP (In Sync)
Image Selected:   secondary                    secondary
Image Booted:     secondary                    secondary
Primary ver:      15.1.2.12                    15.1.2.12
Secondary ver:    15.4.1.3                     15.4.1.3
                  patch1-5                     patch1-5
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 15.4.1.3
                  631635 bytes saved on Wed Jul 16 14:17:31 2014
Can you please help us to debug and found the clue of this problem and how we can fix that?
Thanks,
Nikolay
Photo of Nikolay Krasko
Nikolay Krasko
  • 120 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
We have PD in EXOS 15.1.
Please create case with TAC so that we can track this issue on EXOS 15.4
Nikolay Krasko
Sumit, what does 'PD' mean?
We are already contacted our regional support though they are working business time only. :(
Sumit Tokle, Alum
Product defect.
Contact Extreme Global TAC if the devices are cover under contract.
Nikolay Krasko
Sumit, thanks for prompt reply. Is that hardware product defect or software?
Sumit Tokle, Alum
Software.
