L2 or L3 Load Sharing
  • Question
  • Updated 4 years ago
  • Answered
Hi!
Is there anyone who can explain a bit about the differences between layer 2 and layer 3 load sharing?
Why would I choose layer 2 before layer 3 for example?
If there's only multicast on the ports, would it be better to use layer 3?
Any information is greatly appreciated.
Thanks!
Photo of Prinfo
Prinfo
  • 24 Points
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Layer 2 will consider only Mac address for hashing
L3 considers Ip .... If it is multicast with different IP subnets l3 should be good
(Edited)
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Hi PARTHIBAN,
Is it Multicast traffic will load shared in a lag???
Photo of rbrt_weiler
rbrt_weiler
  • 834 Points 500 badge 2x thumb
Additionally, when using L3 routing algorithms you can benefit of "equal cost load balancing", which actually distributes traffic based on link load.
Photo of Paul
Paul
Hi Robert,
Could you explain more about L3 routing protocol to "equal path load balancing" for traffic to distributes the load on links. Thanks.
rbrt_weiler
Hi Paul,
Just ask Google about it. For example, it leads to this Wikipedia article: http://en.wikipedia.org/wiki/Equal-cost_multi-path_routing
The common routing protocol to use in a LAN is OSPF by the way. Again, Google knows a lot about it.
Photo of Paul
Paul
Thanks anyway Robert, Here i am in the HUB.
