LACP between Enterasys S-Series and Extreme SummitX XOS16.1
  • Question
  • Updated 3 years ago
  • Answered
Hey Guys,
need a little bit assistance for a LACP (2 sfp+ ports) between the Enterasys S Series and a Extreme SummitX X670G2-48x-4q .
Found some example for Extreme:
enable sharing 10 grouping 10-12 lacp
configure sharing 10 lacp system-priority 3
configure sharing 10 add port 5
The Enterasys Side is no problem, but is that realy all what i have to do?
Admin Key? e.t.c?
regards
Jens
Photo of Jens Podbiera
Jens Podbiera
  • 210 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
Jens,
No ... it is simpler than that.. On the XOS side it is just one line...
enable sharing <master port> grouping <port list> lacp
So.. if you have port 1,2 on the xos side:
enable sharing 1 grouping 1,2 lacp
Bill
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
Normally only the enable sharing command is enough to get lacp working.
To get proper distribution between the ports using a good load share algorithm is advised, preferably L3_L4. See this document.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-or-delete-a-share-group-in-EXOS
(Edited)
Jens Podbiera
Wow, thank you for the fast response!
Thank You!
Jens Podbiera
Hey Guys, works great, but this is my first Extreme Swtich and now i tryed to attach tagged Vlans to my lag Group.
Cant found the right Syntax. Should i add the tagged Vlan to the physical port or to the lag?
regards
Jens
All you do is add the <master port> to the vlan in question....
Example... Add port 3 to vlan test...   "configure test add port 3 tagged"
Assume you created the vlan test with tag  ... Ex...  "create vlan bill tag 10"
Bill
Jens Podbiera
Awesome responsetime, thank you for this!
now all works great!
