LACP ports from B3 vs B5 Enterasys Switch
  • Problem
  • Updated 2 years ago
  • Solved
Is there a difference between these two switches when configuring LACP?  We replaced a B3 with a B5 switch with identical configuration and the LACP ports appeared to create a loop. The only difference between these two units (besides model) would be the B5 had a newer firmware 06.81.04.0001. Any suggestions would be appreciated.
Photo of Mark Robinson
Mark Robinson
  • 330 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Careno, Ryan
Careno, Ryan, Employee
  • 1,092 Points 1k badge 2x thumb
Hello,
On B3 switches, we used to have LACP enabled by default on all ports.  On B5 switches, we no longer have LACP enabled per port by default, as there were complaints about LAG groups automatically forming when two links were connected between switches.
You will need to turn on LACP on the ports with command "set port lacp port PORT_STRING enable".
Regards,
Ryan Careno
Extreme Networks GTAC
Mark Robinson
To confirm, lacp ports would require this command such as:
set port lacp port ge.1.46-48 enable"
Is this correct?
Mark,
That is correct.  B5 configuration does not have that command enabled for the ports like the B3 has.  Setting that command should bring the LAG up.  You can also verify if LACP packets are being broadcast every 30 seconds on ports with command "show port lacp port ge.1.46-48 counters" and look at the LACPDU TX and RX values for transmitted and received.
Regards,
Ryan Careno
Mark Robinson
Thanks Ryan. I believe that will resolve the issue. Also much appreciated for the prompt reply.
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,772 Points 2k badge 2x thumb
Mark,
The short answer is that they should be almost identical.  Depending on what has changed in firmware of course.
Can you post the lacp and port configurations from each?
show port status for the lag port and underlying physical ports
show lacp lag.0.x
show lacp groups
and the spanning tree configuration
Mark Robinson
Thanks. Here is the lacp and port configs on the existing B3 switch which match the new B5 switch.
set lacp aadminkey lag.0.1 10
set port lacp port ge.1.46 aadminkey 10
set port lacp port ge.1.47 aadminkey 10
set port lacp port ge.1.48 aadminkey 10
set port vlan ge.1.1-45 520
Port Status
ge.1.1                 Down    Up      N/A       N/A     BaseT RJ45
ge.1.2                 Up      Up      100.0M    full    BaseT RJ45
ge.1.3                 Up      Up      100.0M    full    BaseT RJ45
ge.1.4                 Up      Up      100.0M    full    BaseT RJ45
ge.1.5                 Up      Up      100.0M    full    BaseT RJ45
ge.1.6                 Up      Up      100.0M    full    BaseT RJ45
ge.1.7                 Up      Up      100.0M    full    BaseT RJ45
ge.1.8                 Up      Up      100.0M    full    BaseT RJ45
ge.1.9                 Up      Up      10.0M     half    BaseT RJ45
ge.1.10                Up      Up      10.0M     half    BaseT RJ45
ge.1.11                Up      Up      10.0M     half    BaseT RJ45
ge.1.12                Up      Up      10.0M     half    BaseT RJ45
ge.1.13                Up      Up      10.0M     half    BaseT RJ45
ge.1.14                Up      Up      10.0M     half    BaseT RJ45
ge.1.15                Up      Up      10.0M     half    BaseT RJ45
ge.1.16                Up      Up      10.0M     half    BaseT RJ45
ge.1.17                Up      Up      10.0M     half    BaseT RJ45
ge.1.18                Down    Up      N/A       N/A     BaseT RJ45
ge.1.19                Down    Up      N/A       N/A     BaseT RJ45
ge.1.20                Down    Up      N/A       N/A     BaseT RJ45
ge.1.21                Down    Up      N/A       N/A     BaseT RJ45
ge.1.22                Down    Up      N/A       N/A     BaseT RJ45
ge.1.23                Down    Up      N/A       N/A     BaseT RJ45
ge.1.24                Down    Up      N/A       N/A     BaseT RJ45
ge.1.25                Down    Up      N/A       N/A     BaseT RJ45
ge.1.26                Down    Up      N/A       N/A     BaseT RJ45
ge.1.27                Down    Up      N/A       N/A     BaseT RJ45
ge.1.28                Down    Up      N/A       N/A     BaseT RJ45
ge.1.29                Down    Up      N/A       N/A     BaseT RJ45
ge.1.30                Down    Up      N/A       N/A     BaseT RJ45
ge.1.31                Down    Up      N/A       N/A     BaseT RJ45
ge.1.32                Down    Up      N/A       N/A     BaseT RJ45
ge.1.33                Down    Up      N/A       N/A     BaseT RJ45
ge.1.34                Down    Up      N/A       N/A     BaseT RJ45
ge.1.35                Down    Up      N/A       N/A     BaseT RJ45
ge.1.36                Down    Up      N/A       N/A     BaseT RJ45
ge.1.37                Down    Up      N/A       N/A     BaseT RJ45
ge.1.38                Down    Up      N/A       N/A     BaseT RJ45
ge.1.39                Down    Up      N/A       N/A     BaseT RJ45
ge.1.40                Down    Up      N/A       N/A     BaseT RJ45
ge.1.41                Down    Up      N/A       N/A     BaseT RJ45
ge.1.42                Down    Up      N/A       N/A     BaseT RJ45
ge.1.43                Down    Up      N/A       N/A     BaseT RJ45
ge.1.44                Down    Up      N/A       N/A     BaseT RJ45
ge.1.45                Down    Up      N/A       N/A     Combo RJ45/SFP
ge.1.46                dormant Up      1.0G      full    Combo RJ45/SFP
ge.1.47                dormant Up      1.0G      full    Combo RJ45/SFP
ge.1.48                dormant Up      1.0G      full    Combo RJ45/SFP
lag.0.1                Up      Up      3.0G      full    lag
lag.0.2                Down    Up                        lag
lag.0.3                Down    Up                        lag
lag.0.4                Down    Up                        lag
lag.0.5                Down    Up                        lag
lag.0.6                Down    Up                        lag
B3(su)->show lacp lag.0.1
Global Link Aggregation state: enabled
Single Port LAGs:              disabled
Aggregator: lag.0.1
                         Actor                  Partner
System Identifier:     00:1F:45:44:8B:28    00:1F:45:9E:72:FC
  System Priority:                 32768                32768
        Admin Key:                    10
         Oper Key:                    10                   10
   Attached Ports:    ge.1.46
                      ge.1.47
                      ge.1.48
B3(su)->show lacp groups
LACP groups supported 6
As stated earlier, the B5 config file matches this B3 identically. When the B5 powered up, it appeared to create a loop and started taking down other network segments. We powered down the B5 switch and all network services returned to normal.
Your thoughts are appreciated.
Photo of Paulo Silva
Paulo Silva
  • 480 Points 250 badge 2x thumb
Hi Mark.
One question, wich vlan are configured the ports ge.1.46-48? Another question did you configure in both switches "set lacp singleportlag enable"?
Regards,
Paulo Mauricio
Mark Robinson
Hi Paulo. Have configured a host vlan and a vlan for voip both tagged on ge.1.46-48 which matches our B3 config. Also noticed on the B3, the "Single Port LAGs" are disabled. Would they need to be enabled on the B5?
I believe the command "set port lacp port ge.1.46-48 enable" on the earlier post should resolve our loop issue but would like to confirm that we would or would not require to enable the "set lacp singleportlag" command.
The command "set lacp singleportlag enable" is only needed when we are initially trying to form the lag with a single port, with the intention to add a second port later down the line.  Without this enabled, it would require two ports to link up for the lag to form.  The behavior of singleportlag is only applicable to creation of the lag, not the operational aspect of it.
If you have singleportlag disabled, form a two port lag, and one of the cables gets disconnected, the lag will still stay operational on the single port even with singleportlag disabled.
Regards,
Ryan Careno
Mark Robinson
Paulo. Thanks for clarifying the singleportlag. Cheers to you and your team.
Paulo Silva
Thks Ryan for explanation. I thinked singleportlag was in case link dow, and only one link still up.
Regards
Paulo Maurício
