LACP system priority
  • Question
  • Updated 10 months ago
  • Answered
 I had created MLAG between X620, If we create on access-switches (sw-1,sw-2,sw-3) LACP priority then what would be  happen?
Suppose i run command on access-switch:
enable sharing 1 grouping 1,2 lacp
configure sharing 1 lacp system priority 100
configure lacp member-port 1 priority 20
configure lacp member-port 2 priority 10
Photo of Alok Shukla
Alok Shukla
  • 944 Points 500 badge 2x thumb
Posted 10 months ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,824 Points 5k badge 2x thumb
If I remember well, the priority is used if not all ports can be part of the LACP.
Example: if you connect 9 ports between two switches then only 8 can be part of LACP so based on the priority one port is chosen.
In your case all access switches can have lacp to mlag 620.
