LACP issue when doing the port mirroring
  • Problem
  • Updated 5 years ago
  • Acknowledged
I really need help from you all, using extremeos 15.3.2.11. Please help. Thanks a billion.
All the LACP ports are getting down when enabling the port mirroring using below commands:
enable mirroring to port 10
config mirroring add port 43
Trunk LACP Ports are set:
Trunk 11: Port 11-12
Trunk 17: Port 17-18
Trunk 43: Port 43-44
Trunk 43: Port 47-48
Photo of Jonathan Yeung
Jonathan Yeung
  • 100 Points 100 badge 2x thumb
Posted 5 years ago
Jonathan Yeung
Whenever we issue the above commands, we will get the error like this:01/13/2014 10:02:31.21 <Info:vlan.msgs.portLinkStateDown> Port 48 link down01/13/2014 10:02:31.18 <Info:vlan.msgs.portLinkStateDown> Port 47 link down01/13/2014 10:02:31.11 <Info:vlan.msgs.portLinkStateDown> Port 46 link down01/13/2014 10:02:31.06 <Info:vlan.msgs.portLinkStateDown> Port 45 link down01/13/2014 10:02:31.04 <Info:vlan.msgs.portLinkStateDown> Port 44 link down01/13/2014 10:02:31.01 <Info:vlan.msgs.portLinkStateDown> Port 43 link down01/13/2014 10:02:30.98 <Info:vlan.msgs.portLinkStateDown> Port 42 link down01/13/2014 10:02:30.95 <Info:vlan.msgs.portLinkStateDown> Port 41 link down01/13/2014 10:02:30.92 <Info:vlan.msgs.portLinkStateDown> Port 40 link down01/13/2014 10:02:30.89 <Info:vlan.msgs.portLinkStateDown> Port 39 link down01/13/2014 10:02:30.87 <Info:vlan.msgs.portLinkStateDown> Port 38 link down01/13/2014 10:02:30.84 <Info:vlan.msgs.portLinkStateDown> Port 37 link down01/13/2014 10:02:30.81 <Info:vlan.msgs.portLinkStateDown> Port 36 link down01/13/2014 10:02:30.78 <Info:vlan.msgs.portLinkStateDown> Port 35 link down01/13/2014 10:02:30.76 <Info:vlan.msgs.portLinkStateDown> Port 34 link down01/13/2014 10:02:30.68 <Info:vlan.msgs.portLinkStateDown> Port 32 link down01/13/2014 10:02:30.64 <Info:vlan.msgs.portLinkStateDown> Port 31 link down01/13/2014 10:02:30.61 <Info:vlan.msgs.portLinkStateDown> Port 30 link down01/13/2014 10:02:30.57 <Info:vlan.msgs.portLinkStateDown> Port 28 link down01/13/2014 10:02:30.55 <Info:vlan.msgs.portLinkStateDown> Port 27 link down01/13/2014 10:02:30.51 <Info:vlan.msgs.portLinkStateDown> Port 26 link down01/13/2014 10:02:30.49 <Info:vlan.msgs.portLinkStateDown> Port 25 link down01/13/2014 10:02:30.44 <Info:vlan.msgs.portLinkStateDown> Port 24 link down01/13/2014 10:02:30.44 <Info:vlan.msgs.portLinkStateDown> Port 23 link down01/13/2014 10:02:30.39 <Info:vlan.msgs.portLinkStateDown> Port 21 link down01/13/2014 10:02:30.32 <Info:vlan.msgs.portLinkStateDown> Port 20 link down01/13/2014 10:02:30.31 <Info:vlan.msgs.portLinkStateDown> Port 19 link down01/13/2014 10:02:30.23 <Info:LACP.RemPortFromAggr> Remove port 18 from aggregator01/13/2014 10:02:30.22 <Info:vlan.dbg.info> Port 18 is Down, remove from aggregator 1701/13/2014 10:02:30.22 <Info:vlan.msgs.portLinkStateDown> Port 18 link down01/13/2014 10:02:30.19 <Info:LACP.RemPortFromAggr> Remove port 17 from aggregator01/13/2014 10:02:30.18 <Info:vlan.dbg.info> Port 17 is Down, remove from aggregator 1701/13/2014 10:02:30.18 <Info:vlan.msgs.portLinkStateDown> Port 17 link down01/13/2014 10:02:30.15 <Info:vlan.msgs.portLinkStateDown> Port 16 link down01/13/2014 10:02:30.12 <Info:vlan.msgs.portLinkStateDown> Port 15 link down01/13/2014 10:02:30.09 <Info:vlan.msgs.portLinkStateDown> Port 14 link down01/13/2014 10:02:30.06 <Info:vlan.msgs.portLinkStateDown> Port 13 link down01/13/2014 10:02:30.03 <Info:LACP.RemPortFromAggr> Remove port 12 from aggregator01/13/2014 10:02:30.02 <Info:vlan.dbg.info> Port 12 is Down, remove from aggregator 1101/13/2014 10:02:30.02 <Info:vlan.msgs.portLinkStateDown> Port 12 link down01/13/2014 10:02:29.99 <Info:LACP.RemPortFromAggr> Remove port 11 from aggregator01/13/2014 10:02:29.98 <Info:vlan.dbg.info> Port 11 is Down, remove from aggregator 1101/13/2014 10:02:29.98 <Info:vlan.msgs.portLinkStateDown> Port 11 link down01/13/2014 10:02:29.95 <Info:vlan.msgs.portLinkStateDown> Port 9 link down01/13/2014 10:02:29.91 <Info:vlan.msgs.portLinkStateDown> Port 8 link down01/13/2014 10:02:29.88 <Info:vlan.msgs.portLinkStateDown> Port 6 link down01/13/2014 10:02:29.85 <Info:vlan.msgs.portLinkStateDown> Port 4 link down01/13/2014 10:02:29.82 <Info:vlan.msgs.portLinkStateDown> Port 2 link down01/13/2014 09:55:36.08 <Warn:HAL.Card.Warning> No port map for port 0:001/13/2014 09:55:36.08 <Warn:HAL.Card.Warning> No port map for port 0:001/13/2014 09:54:00.81 <Info:AAA.authPass> Login passed for user admin through serial01/13/2014 09:54:00.81 <Erro:AAA.TACACS.goLocal> Failed to send authentication to 10.254.245.58 trying local.01/13/2014 09:54:00.81 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.254.245.58 error=-101/13/2014 09:53:57.80 <Warn:AAA.TACACS.swapHost> Swap host to 10.254.245.5801/13/2014 09:53:57.80 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.245.166.149 error=-101/13/2014 09:53:50.27 <Warn:AAA.authFail> Login failed for user edwardchu through serial01/13/2014 09:53:50.27 <Erro:AAA.TACACS.goLocal> Failed to send authentication to 10.254.245.58 trying local.01/13/2014 09:53:50.27 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.254.245.58 error=-101/13/2014 09:53:47.27 <Warn:AAA.TACACS.swapHost> Swap host to 10.254.245.5801/13/2014 09:53:47.27 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.245.166.149 error=-101/13/2014 09:53:34.96 <Info:AAA.logout> User ptc logout from serial01/13/2014 09:53:03.71 <Info:AAA.authPass> Login passed for user ptc through serial01/13/2014 09:53:03.69 <Erro:AAA.TACACS.goLocal> Failed to send authentication to 10.254.245.58 trying local.01/13/2014 09:53:03.69 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.254.245.58 error=-101/13/2014 09:53:00.69 <Warn:AAA.TACACS.swapHost> Swap host to 10.254.245.5801/13/2014 09:53:00.69 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.245.166.149 error=-101/13/2014 09:48:03.45 <Info:LACP.RemPortFromAggr> Remove port 48 from aggregator01/13/2014 09:48:03.45 <Info:LACP.RemPortFromAggr> Remove port 47 from aggregator01/13/2014 09:47:14.22 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.254.245.58 error=-101/13/2014 09:47:11.22 <Warn:AAA.TACACS.swapHost> Swap host to 10.254.245.5801/13/2014 09:47:11.22 <Erro:AAA.TACACS.sockwriteError> Error writing to remote host 10.245.166.149 error=-101/13/2014 09:47:08.22 <Info:AAA.logout> User ptc logout from telnet (10.254.245.58)01/13/2014 09:46:52.97 <Info:LACP.RemPortFromAggr> Remove port 44 from aggregator01/13/2014 09:46:52.82 <Info:LACP.RemPortFromAggr> Remove port 43 from aggregator01/13/2014 09:45:44.66 <Warn:HAL.Card.Warning> No port map for port 0:001/13/2014 09:45:44.66 <Warn:HAL.Card.Warning> No port map for port 0:0
Jonathan Yeung
anybody, please help me. Thanks a lot
Photo of Ron Huygens
Ron Huygens, Employee
  • 3,370 Points 3k badge 2x thumb
Hello Johnathan,
Without knowing the switch platform and further configuration, it is very hard to comment on this.
For sure it is not expected behavior, enabling mirroring on a port should normally not affect the link state on any other ports.
Therefore I suggest that you open a TAC case through your normal support channel for proper investigation.
Thanks,
Ron
Photo of Tamera Rousseau-Vesta
Tamera Rousseau-Vesta, Extreme Alumna
  • 2,760 Points 2k badge 2x thumb
Jonathan, if you could provide us some further clarification on this issue, we would like to work with you to resolve.  Thank you!
Jonathan Yeung
Thanks a lot Tamera and Ron, we are working with extreme support on this. Thanks a lot
